Author Topic: Power Steering Pump 2.5 V6 1999  (Read 1879 times)
jasonxr2racer
  • North West
« on: 16 May 2008, 13:09:56 »
My power steering pump has gone noisy (bearing noise)
Would this be ok to drive for now until I can get one?
Is it a ball ache to change?
Are there different types?
serek
  • huntingdon
    • 3.2 mv6
Re: Power Steering Pump 2.5 V6 1999
« Reply #1 on: 16 May 2008, 13:28:21 »
if is not very noisy can  drive for litlle
 3.0 and 2,5  look same, but not sure
jasonxr2racer
  • North West
« Reply #2 on: 16 May 2008, 15:08:45 »
It is quite noisy but only just started.
When i rang parts place they needed a number off the pump to match it up.
Said there are about 4 different ones?
serek
  • huntingdon
    • 3.2 mv6
« Reply #3 on: 16 May 2008, 16:18:21 »
give for them reg nr and they should know
Richard A
  • Aldridge, West Midlands
« Reply #4 on: 16 May 2008, 18:28:34 »
To get by, spray WD40 at pump shaft seal, through the holes in the pulley or from the back of the pump.
regards
richard a
richard a
jasonxr2racer
  • North West
« Reply #5 on: 17 May 2008, 20:16:16 »
regards
richard a
Yeah did that and it starts agian not long after.
Just want to know if It will be ok to drive and not fall apart cos I'm going to Anglesey next friday night as I'm racing there.
Richard A
« Reply #6 on: 17 May 2008, 20:23:13 »
My pump went without the warning yours has given you, change it, if it goes on your trip you will have BIG problems, steering is VERY hard. Cost of pump about £105 plus fitting.
regards
richard a
richard a
Mike Collins
  • North of Bristol
« Reply #7 on: 17 May 2008, 22:07:03 »
You should be able to find a used pump, if it's similar to our 98 2.5 it's not hard to change.
Some used pumps have the the inlet stub at the wrong angle, you can realign the stub after heating to soften the locking compound.
