Author Topic: Dashboard lamps access?  (Read 3122 times)
Mike Collins
  • North of Bristol
Re: Dashboard lamps access?
« Reply #15 on: 18 May 2008, 10:31:48 »
Try Autobulbs Direct, R509TGR0, 12V 2W green base. £7.5 for a pack of ten. These will fit the MID.
They may also have these;
The bulbs in the climate panel are the same base but 12V 1.2W, you may be able to separate the bulb from the base, Farnell part 113-9322 gets you the bulb.
There are five, change them all while you have it bits.
The panel illumination bulbs are 12V 2W, wedge T3, Farnell part 113-9442.
I think there are four.
perfferle
  • North Yorkshire
  • All cats are grey in the dark!
« Reply #16 on: 18 May 2008, 18:51:13 »
Thanks mike :y
