Author Topic: OBD II Scanners  (Read 1812 times)
valliant72
  • London
OBD II Scanners
« on: 21 May 2008, 15:21:36 »
Hi, Do any of the scanners that are available on Ebay work with a 2000 omega 2.5. Though of getting one incase of future problems, thought it maybe easier than doing the paper clip test. Thanks
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: OBD II Scanners
« Reply #1 on: 21 May 2008, 15:23:46 »
By scanners do you mean the cheapo Tech 2's??
valliant72
  • London
Re: OBD II Scanners
« Reply #2 on: 21 May 2008, 15:37:55 »
Im not sure, there meant to read fault codes and give live data.
http://cgi.ebay.co.uk/GS500-OBD-II-2-Scanner-Diagnostic-Trouble-Code-Reader_W0QQitemZ290230981294QQcmdZViewItem?hash=item290230981294&_trkparms=72%3A12%7C39%3A1%7C65%3A12&_trksid=p3286.c0.m14, ive put a link if thats ok to the one ive seen. if i shouldnt of put the link, i'll delete it.
Re: OBD II Scanners
« Reply #3 on: 21 May 2008, 15:58:11 »
OBD-II scanners won't work on a 2.5, unfortunately. OBD-II came with the transition to 2.6 / 3.2 engines.
valliant72
  • London
Re: OBD II Scanners
« Reply #4 on: 21 May 2008, 15:59:21 »
ok, thanks for the replies
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: OBD II Scanners
« Reply #5 on: 21 May 2008, 19:30:27 »
opel-scanner will work but a lot more than a paper clip
that said does more than a paper clip.
works on vx cars and some saab from 87 - 2008
now has generic in menu not sure what that will work with -
other car with new "can wiring standard" ?
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
MV6Man
  • Finland
Re: OBD II Scanners
« Reply #6 on: 21 May 2008, 19:44:49 »
I´ve been thinking that opel-scanner too.
It needs laptop though.
But, with it you should be able to change some parameters too
« Last Edit: 21 May 2008, 19:45:51 by MV6Man »
iggy21uk
Re: OBD II Scanners
« Reply #7 on: 21 May 2008, 22:23:52 »
Keys - Only if you have Car pass.
Been to busy to use mine !
Mike Collins
  • North of Bristol
Re: OBD II Scanners
« Reply #8 on: 21 May 2008, 22:35:18 »
Opel scan can encode transponder keys, I've not yet found a way to match remote RF keys with it.
It does at least give you a mechanical key that will start the car.
