Author Topic: Aux belt change help  (Read 1666 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 21 May 2008, 18:57:29 »
Looking to change my Aux belt on saturday i know that i need a 15mm spaner to take the tension off but can any one give me a walk by on how i do this. Is it the pully at the left of the engine as you look at it from the front. Have a belt on hold at parkers up the road.
Thanks for the help
markey mark
  • SLady bitshorpe north lincs
Re: Aux belt change help
« Reply #1 on: 21 May 2008, 18:59:49 »
just pop spanner on nut on front f tensioner and pull to the right and slip belt off but remember to check the routing of belt !! :y
jonathanh
  • coventry
« Reply #2 on: 21 May 2008, 19:25:39 »
yep. pulley on the left of the engine.  It's real easy but if you get stuck and you are in cov, pm me and i'll give you a hand.
15mm socket will also do the trick as long as it is a good fit - you don't want the ratchet slipping off.  I'd also regrease the tensioner bearing while I was there if I were you.  takes about 5 minutes
« Reply #3 on: 21 May 2008, 19:32:52 »
Take a digi picture of belt before removing - its amazing how many people cant work out how to route it on refitting ;D
SP_3.2
  • Leicester
« Reply #4 on: 21 May 2008, 22:15:59 »
Thanks guys that sounds not to hard at all will give it a go. Thanks of the offer of a helping hand Jonathanh will give you a PM if i get stuck :y :y
« Last Edit: 21 May 2008, 22:17:30 by SP_3.2 »
« Reply #5 on: 21 May 2008, 23:07:36 »
Might be worth changing the tensioner pulley as well while you're at it. IIRC, yours was "re-greased" at Shifnal after getting a bit graunchy?  :y
SP_3.2
  • Leicester
« Reply #6 on: 22 May 2008, 06:50:27 »
Thanks  Kevin good point :y
« Reply #7 on: 22 May 2008, 08:46:39 »
And you can just buy the pulley, you dont have to buy the whole tensioner assembly.
