Author Topic: Engine shaky ?  (Read 2151 times)
marinis69
  • Ashford
Engine shaky ?
« on: 20 May 2008, 11:48:04 »
Any one had a problem when the engine doesn't produce full power. At the begining one cilinder wasnt working at all. I have changed spark plugs, coil pack, and spark plugs. It seem got better but still its a bit slow and sometimes shaky. Any ideas what else might be? I thought about injectors but dont want to change them if it is not the problem.
marinis69
  • Ashford
Re: Engine shaky ?
« Reply #1 on: 20 May 2008, 11:48:56 »
and ignition leads :) as well
Mike Collins
  • North of Bristol
Re: Engine shaky ?
« Reply #2 on: 20 May 2008, 12:07:19 »
Oil in plug wells?
Dave-C
  • Staffordshire
  • The Old Girl
Re: Engine shaky ?
« Reply #3 on: 20 May 2008, 20:01:22 »
Gunged up throttle body?  Grotty ICV?
marinis69
  • Ashford
Re: Engine shaky ?
« Reply #4 on: 20 May 2008, 22:23:34 »
just have changed coil pack, ignition leads and spark plugs. no oil leak on plugs nothing. the engines starting to gain power just over 3000 rpm but on low its shaking and hasn't got much power. I had the same omega 2.5 v6 just cd model and it was like a roket, but this one seems to strugle a bit. Thinking about connecting computer at the garage maybe it will tell something.
rickyboy
  • Glasgow
Re: Engine shaky ?
« Reply #5 on: 21 May 2008, 12:43:43 »
Engine management light working ok?  Sounds like it's running in limp mode.  Turn the ignition on to position 2 without cranking the engine - does the light with the engine symbol appear?  With such a lack of power up to 3000rpm i'd imagine the light to come on.
marinis69
  • Ashford
Re: Engine shaky ?
« Reply #6 on: 21 May 2008, 12:56:46 »
No light comes off. I have left the car for engine diagnostic today. Will see what computer say.
JasonH
Re: Engine shaky ?
« Reply #7 on: 22 May 2008, 15:05:57 »
If no fault codes show it could be a partially blocked exhaust - car will still run but power will be way down.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
Re: Engine shaky ?
« Reply #8 on: 22 May 2008, 15:11:03 »
EGR valve stuck open?
