Author Topic: Headlamp washers  (Read 1297 times)
minimeee
Headlamp washers
« on: 23 May 2008, 17:32:15 »
hi guys my headlamp washers are not working any ideas? i'm guessin the pump is the smaller of the 2 attached to the water tank (the bigger being the windscreen pump at a guess)
any ideas?
Dazzler
  • Haverhill, Suffolk
Re: Headlamp washers
« Reply #1 on: 23 May 2008, 18:10:50 »
Looking from the front, the headlamp one is the R/H of the 2. If the motor is running then i would suggest the filter is blocked. To clean the filter just pull the pump out from the tank, the filter is the rubber bung that can now be seen, remove this and clean/replace.
« Reply #2 on: 23 May 2008, 18:12:45 »
any ideas?
Other way round. The headlamps are washed with a greater pressure than the screen.
« Reply #3 on: 23 May 2008, 18:20:12 »
Cars with head lamp washers need to have a strong mix of washer fluid. Otherwise they block up
minimeee
« Reply #4 on: 23 May 2008, 18:30:45 »
been out n checked, with headlights on jammed stalk and the smaller pump goes but biggin doesnt, also took it out (youz coulda told me the water tank would empty lol ;D ) and no blockage at first sight
« Reply #5 on: 23 May 2008, 18:34:43 »
You did'nt ask that
You only wanted to know if we had any idea's why they wernt working.    ;D ;D ;D ;D ;D ;D
minimeee
« Reply #6 on: 23 May 2008, 19:00:01 »
so safe to assume the pumps pumped?
