Author Topic: Fault codes  (Read 2573 times)
JezInBrum
  • Birmingham
  • Built for comfort not speed
Fault codes
« on: 15 May 2008, 09:41:57 »
Hi, followed the how to guides on the forum and read off fault code.
It was...
89   O2 Sensor 2 Open Circuit. Only thing i can think of is a lambda probe/oxygen sensor on the down pipe. I am most likey wrong but would appreciate advice off anyone that would know please? Also is that code if it is as I think specific to either of the sensors.
Thanks, Jez
« Last Edit: 15 May 2008, 10:14:54 by JezInBrum »
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #1 on: 15 May 2008, 12:30:07 »
As well as the code issue, is there anyone with Tech2 in Birmingham area who could check for other issues as with rest of car as well please? Car also has a Gearbox fault. Fluid levels ok & selector swicth seem to be behaving ok. Would refund costs & bung on a few quid for a drink for anyone who can assist. Thanks
Re: Fault codes
« Reply #2 on: 15 May 2008, 13:30:51 »
It was...
Thanks, Jez
It does sudgest an O2 sensor fault, sensor number 2 is the passenger side (2-4-6 bank)
Do check its plugged in properly and examine the wiring around the sensor and gearbox for damage.
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #3 on: 15 May 2008, 15:31:15 »
Thanks Mark, I shall have a look tomorrow as the weather had turned wet.
Will also examine the selector switch woring whilst I am there.
Anyone help with the Tech 2?  ;)
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #4 on: 15 May 2008, 22:24:33 »
Somebody must know of someone local with one please?  ;)
Re: Fault codes
« Reply #5 on: 16 May 2008, 08:41:09 »
Birmingham is a big place, you would need to be a bit more specific about where!
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #6 on: 16 May 2008, 11:39:41 »
Erdington/North
Re: Fault codes
« Reply #7 on: 16 May 2008, 11:43:15 »
The best I can offer is a 1 hour drive up the M42.....to south Nottingham
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #8 on: 16 May 2008, 12:46:54 »
Thanks Mark. The reason for tech 2 request  is due to the car flagging an autobox fault on the MID. Oil level is ok but I dont really want to risk an hours drive without knowing what the chances of causing terminal damage is. If no other offers are forthcoming very soon I will contact you if that is ok?
Many thanks, Jez
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #9 on: 18 May 2008, 14:27:23 »
Hi again, follow up on the code 89 issue. I have taken a pic of the oxygen sensor. Am after opinions on whether the damage shown would be enough to render if knackered & warrant replacement.
« Last Edit: 18 May 2008, 14:45:41 by Mark »
Re: Fault codes
« Reply #10 on: 18 May 2008, 14:44:51 »
That sir..........is beyond repair!
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #11 on: 18 May 2008, 16:41:53 »
Thanks for that, one problem solved at least.  ;)
motmann
  • birmingham
Re: Fault codes
« Reply #12 on: 18 May 2008, 19:37:09 »
if you can get to halesowen/oldbury j2 m5 i will do a code read for you, engine and gearbox?
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #13 on: 19 May 2008, 17:39:40 »
thank you motmann. I will get sump back on gearbox, fill with oil 7 pray the fluid & filter change have doen the trick.
Wil be in touch soon after if not  :y
JezInBrum
  • Birmingham
Re: Fault codes
« Reply #14 on: 23 May 2008, 22:05:54 »
Hello again. Had the gearbos ECU read today interesting result. Trouble coded P1850 present. Shift solenoid C open circuit. Diagnosis is defective ECU as it drives fine when cold or a damaged wire. But the fact fault occurs when warn leads to then ECU. To top it all I can locate a million & 1 of them on ebay, just not the one I want...typical lol. For anyone that has one the numbers are 96041456, ident CK.
