Author Topic: checking auto box level  (Read 1044 times)
Arpy
  • Preston
  • 02 2.2 cdx estate auto
« on: 23 May 2008, 10:15:47 »
I have read a thread re checking the oil level but I seem a bit confused on how to jack up car could someone try and explain how I can check the level.
I do not have access to a ramp so I will be doing it on the road which is reasonbly flat
cheers
Dazzler
  • Haverhill, Suffolk
Re: checking auto box level
« Reply #1 on: 23 May 2008, 18:12:36 »
You need the car raised in the air but still level, so all 4 corners need to raised and supported before you can go under to check the level.
Arpy
  • Preston
« Reply #2 on: 24 May 2008, 09:47:23 »
ok so car level now how do i know if oil level fine do i check with engine off or when running
« Reply #3 on: 24 May 2008, 09:48:59 »
Engine running.
If the oil has been in there a while, expect a load to come oil (ATF expands as it breaks down).
