Author Topic: Gates cam belt kits  (Read 3135 times)
Re: Gates cam belt kits
« Reply #15 on: 23 May 2008, 23:56:27 »
I've fitted the SKF kit and they do indeed come with gates belts, complete with markings. :y
Got mine from Autovaux, IIRC.
« Reply #16 on: 24 May 2008, 21:32:06 »
So what would you expect to pay for a water pump then ?
I got all my parts for the last service, except the belt kit, from andyc and the water pump was less than £30.
Richie London
  • heathrow
« Reply #17 on: 25 May 2008, 11:27:58 »
As Loo-Knee says, this place is cheap and they deliver quickly :y
https://sslrelay.com/buypartsby.co.uk/timing-belt-kit-info.php?recordID=6720
saved to favs, shall buy mine in couple of weeks now im back at work
richie
mkaminski100
  • Basingstoke
« Reply #18 on: 25 May 2008, 13:38:48 »
Gates belts tend to snap. These are in mid quality in Opel list.
SKF pumps are not as good as they used to be - I've heard about noisy ones and leaking.
If you are looking for a good quality parts, go for:
- belts: Conti-tech, Bosh
- tensioners - INA (GM supplier)
- pumps - GRAF,Ruville (not as good as GRAF but reliable).
Conti belt + INA tensioners/pulleys  + GRAF pump = ca 120 Pounds
