Author Topic: Help needed!!  (Read 2974 times)
JoYneC
Help needed!!
« on: 19 May 2008, 22:28:51 »
hi all! i have a 96 omega that i hace swapped engine from x20xev to  x25xe.
when i had the engine out i changed the timing belt, headgaskets, dis pack, ht, spark plugs, crank sensor, maf sensor.
there is spark and the engine gets fuel but it just wont start  :-[
had it at vaushall dealer but they couldnt figure out whats wrong...
anyone had same problem? or any ideas?
(sorry if my englidh is bad, im from norway  :P)
shanjon
Re: Help needed!!
« Reply #1 on: 19 May 2008, 22:45:02 »
i may be way off here m8 but im assuming you changed the ecu and transponder and key chip so they all match
JoYneC
Re: Help needed!!
« Reply #2 on: 19 May 2008, 22:48:15 »
yes, the vauxhall dealer fixed it for me...
Re: Help needed!!
« Reply #3 on: 20 May 2008, 00:01:16 »
presumably, you changed the entire engine loom, too?
Re: Help needed!!
« Reply #4 on: 20 May 2008, 00:02:46 »
In these situations I think of "suck, squeeze, bang, blow"
For an engine to run, you need air, fuel, and spark on compression - you need to find which one you're lacking :D
I'll follow this with interest.
Have you any fault codes stored?
JoYneC
Re: Help needed!!
« Reply #5 on: 20 May 2008, 10:20:11 »
i have also done a compression test an it was fine...ive changed the entire loom yes ;)
dosent seem like im missin any of those things thats vhats bugging me..
seems like the cars misfiring...
i can post a video later of when im turning the key so you can listen ;)
only fault code i can remember that i got was egr valve but the car should start anyway?
« Last Edit: 20 May 2008, 10:22:06 by JoYneC »
Re: Help needed!!
« Reply #6 on: 20 May 2008, 10:30:26 »
If you have compression, spark, fuel and "missfire" .. then its either igntion timing or valve timing.... I'd imagine the valve timing hasn't been touched .. so it's ignition timing .....
and the most common cause of problems there is wrong lead to wrong plug !!
so check from DIS pack to plugs to ensure you have the correct connections.... otherwise the spark is happening on an open cylinder !!
« Last Edit: 20 May 2008, 10:31:13 by entwood »
JoYneC
Re: Help needed!!
« Reply #7 on: 20 May 2008, 11:56:24 »
ive checked the igniting timing several times and it stands correct....adding av video of my car here:
http://www.speedyshare.com/523821658.html
JoYneC
Re: Help needed!!
« Reply #8 on: 21 May 2008, 10:55:59 »
nobody have any ideas?
rickyboy
  • Glasgow
Re: Help needed!!
« Reply #9 on: 21 May 2008, 12:21:19 »
There might be a few that advise against this but a can of cold start from halfords will start just about anything.  I'd give it a try and see what happens, just spray a little in the air intake.
JoYneC
Re: Help needed!!
« Reply #10 on: 21 May 2008, 19:44:44 »
tried that, didnt work :P
Jay w
  • Plymouth/Poole
  • omega gone
Re: Help needed!!
« Reply #11 on: 21 May 2008, 22:34:57 »
When you changed the cambelt did you use a locking kit?
I wonder if the cam timing is incorrect....bit of a long shot
JoYneC
Re: Help needed!!
« Reply #12 on: 21 May 2008, 23:10:18 »
didnt do it the first time.....but did it after i found out how sensitive a v6 was.....vauxhall checked it and said it was correct but i wonder if i have the cams 180degrees out så i will turn them this weekend an will see if it fires then ;)
JasonH
Re: Help needed!!
« Reply #13 on: 22 May 2008, 14:54:46 »
I'd read the fault codes and see if the car will give you a clue...
JoYneC
Re: Help needed!!
« Reply #14 on: 22 May 2008, 17:00:43 »
tried turning the cams 180deegres but didnt help.....no faultcodes found  :-[
