Author Topic: Adding Cruise Control  (Read 1377 times)
ratboyab
« on: 25 May 2008, 03:12:56 »
I recently brought a 1998 Omega CD 2.5l V6 Saloon off of ebay and didn't realise until I brought it home that it hadn't got cruise control. I was wondering if anyone knows how easy / difficult it is to fit and how much it would cost. I found the stalk and cruise control unit on ebay, is this all I need or is there other parts / more work to do? Any help would be appreciated. Thankyou
markey mark
  • SLady bitshorpe north lincs
Re: Adding Cruise Control
« Reply #1 on: 25 May 2008, 12:43:03 »
very easy to fit fella you need control box bowden cable and indicater stalk and brake pedal switch if manual you also need clutch pedal switch  :y
ratboyab
« Reply #2 on: 26 May 2008, 11:25:50 »
Is it literally as easy as basically plugging it all in? The brake pedal switch sounds like that may be a bit more of a challenge but doesn;t sound too difficult. Have you done this before? Thanx for your help mate.
jules
  • Edinburgh
  • Woke up this morning a post whore
« Reply #3 on: 26 May 2008, 11:32:01 »
The search engine is your friend !!!!
http://www.omegaowners.com/forum/YaBB.pl?num=1166374649
Hotel21 wrote 'Its doubtfull in the extreme if it is the head gasket at fault.  If it were burning 5 litres per week the car would leave a smokescreen behind it!'
jonathanh
  • coventry
« Reply #4 on: 26 May 2008, 12:03:09 »
Yep - it really is as easy as plugging it in!  Follow the guide on here.  the brake pedal switch isn't easy simply because of access: not the easiest thing to get to.
Well worth doing however
« Reply #5 on: 26 May 2008, 14:38:55 »
Yup, just a case of plugging it all in :).  The pedal switches are fiddly, but otherwise, very easy job
ratboyab
« Reply #6 on: 26 May 2008, 16:07:19 »
Thanx alot guys, you've been a great help - Adam
