Author Topic: Performance and MPG not up to scratch / autobox  (Read 8099 times)
subliminal
Re: Performance and MPG not up to scratch / autobox
« Reply #45 on: 26 May 2008, 12:11:14 »
It crawls forward/backwards on the flat, stationary on slight inclines - haven't stopped on a steeper incline yet (will give that a go). Had a look around for guidelines to changing the ATF and got some help with torque values in http://www.omegaowners.com/forum/YaBB.pl?num=1211201164. Got about about six litres out I think - will pop into the shed later and check how much ATF is left in the jug..
subliminal
« Reply #46 on: 26 May 2008, 20:57:15 »
Still rolls back on a steep incline (but then, it was a pretty steep incline) - not sure if this is normal behaviour.
« Reply #47 on: 26 May 2008, 22:40:41 »
roll back on steep incline was norm, on my 99cdx. The car in my experience will not account for holding on any given slope. It would roll forward at between 4/5 mph on flat, with both feet off pedals. If you where to drive it up an increasing incline it would come to a point when the slope would b enough for the car to come to a halt, if you drove further up to a steeper part it would roll back to a point that tick over would stop it.This will vary with your tick over problems i am sure. I had constant agro with my icv after it packed up(car stalled) had to remove and wash out with carb cleaner 5 or 6 times to get working again, and once a month to keep on top of it. Did not notice any prob.with a fault code if left un plugged, just plugged it back in.
 The rubber bit to plenum never fitted well
So wrapped electrical tape round the ribbed bit to keep it air tight, and replaced it every time i cleaned it. Front multi ram
on myn stopped working koz i got the vac pipes wrong way round at the bottom of bag pipes(air intakes). Easy done. If you notice a step at 4k rpm try swapping the pipes around on the vac tank(if it has one, see guide) at the bottom of bag pipes? Should be able to see it working by blipping the throttle from the engine bay. Ttfn.
Pages: 1 2 3 [4]  All   Go Up
Page created in 0.01 seconds with 14 queries.
