Pages: 1 [2] 3  All   Go Down
Author Topic: Front shocks  (Read 10209 times)
jonathanh
  • coventry
Re: Front shocks
« Reply #15 on: 26 May 2008, 19:46:46 »
Does anyone know the part numbers for the front shocks and the self-levelling rear shocks for a facelift MV6?
My problem is that my car is an Elite, but with MV6 springs all round. I'm going to change all 4 shocks for the self-levelling MV6 shocks from Vx.
Also any advice if my local Vx stealer doesn't give me good TC prices?
From what I gather from this thread, and Tunnie's, is that the fronts sould be roughly 46+VAT and the rears around 45+VAT. So £220 should cover the full set, but I know that when I asked about a set of springs Evans Halshaw in Bedford quoted nearly £600, and I did tell them I had a TC, but I think they just ignored this.
 :o :o :o :o
Just for springs??
I bought KYB ones from a local motor factor, which are same as OEM i belive.
£44 each  :D
My local stealer knows me now, so can almost always get TC  :)
I should be doing my rear shocks this weekend if thats any use?
Dealers want silly money for springs:  I laughed at them a couple of years ago and they agreed their price was stupid.  KYB are the way to go
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Front shocks
« Reply #16 on: 26 May 2008, 19:59:27 »
So is KYB the way to go for shocks too, or are Vx ones the best?
Re: Front shocks
« Reply #17 on: 26 May 2008, 20:28:52 »
That would be a lot of use!
You're not too far from me in the Brackley area aren't you? Would you ask your dealer what the part numbers and prices are please?
MV6 for a self-levelling version.
Are they an easy job to change yourself, or should I get them done at WIM seeing as I'll have to get the car set up again anyway?
Unlikely a dealer will be able to tell you the part without extensive research.  There are lots and lots of shocks available, and they'll go either by VIN or by ident number of fitted shock, none any good to you.
Albatross
  • Bedford
Re: Front shocks
« Reply #18 on: 26 May 2008, 20:30:29 »
Mmmm, I'm going to have to find another member with a 3.2 MV6 that has self levelling.
Re: Front shocks
« Reply #19 on: 26 May 2008, 20:39:19 »
does anyone have the part number for standard rear shocks to hand?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #20 on: 26 May 2008, 21:13:01 »
Looking at EPC there is only one self levelling shock listed nowadays 72119084 which will be the same as you've got fitted on your elite already.
TuBy's new whipping boy.
Albatross
  • Bedford
Re: Front shocks
« Reply #21 on: 26 May 2008, 21:15:31 »
Cool ta! :y
Can you tell me the part numbers for MV6 front and MV6 rear shocks too please? This is for a 3.2 facelift.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #22 on: 26 May 2008, 21:17:07 »
Non levelling shocks 90542942
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #23 on: 26 May 2008, 21:21:04 »
Cool ta! :y
Only thing I can find is this.
SHOCK ABSORBER, ASSY., WITH MOUNTING PARTS (IDENT WM) (USED WITH LOWERED SPORTS CHASSIS) (FOR ARMOURED BODY) (FOR POLICE VEHICLE) (NOT USED WITH LOWERED SPORTS CHASSIS)    72119086
So its used with the lowered sports chassis and its not used with the lowered sports chassis.
Albatross
  • Bedford
Re: Front shocks
« Reply #24 on: 26 May 2008, 21:21:42 »
So is there a difference between Elite and MV6 shocks?
I'm confused:
There must be at least 4 different types, but I can't work out which is which:
Fronts
Rear Self levelling
Rear non-self levelling
Rear Sports chassis (MV6)
Any chance of a part number for each of the above?
« Last Edit: 26 May 2008, 21:25:51 by Albatross »
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Front shocks
« Reply #25 on: 26 May 2008, 21:22:28 »
Albatross Euro Car parts deal direct with Sachs Bogue who make the omega shocks for vauxhall try them see if they are cheaper than tc
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #26 on: 26 May 2008, 21:29:51 »
I'm confused:
Fronts
Rear Self levelling
Ok rears
Levelling       72119084
Non levelling 90542942
MV6             72119086 if you assume they are used with the sports chassis.
Fronts I'm still working on.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #27 on: 26 May 2008, 21:35:47 »
MV6 fronts look like
SHOCK ABSORBER, ASSY., FRONT, WITH BRAKE HOSE BRACKET, LH-RHD (IDENT LP) (USED WITH LOWERED SPORTS CHASSIS) (EXC.ARMOURED BODY/HEARSE) (NOT USED WITH INCREASED PAYLOAD) (EXC.BAD ROAD PACKAGE) Y26SE, Y32SE   9192291
SHOCK ABSORBER, ASSY., FRONT, WITH BRAKE HOSE BRACKET, RH-RHD (IDENT LP) (USED WITH LOWERED SPORTS CHASSIS) (EXC.ARMOURED BODY/HEARSE) (NOT USED WITH INCREASED PAYLOAD) (EXC.BAD ROAD PACKAGE) Y26SE, Y32SE   9192292
elvin315
  • Catskill, New York, USA
  • Catera...Cadillac's unloved stepchild.
Re: Front shocks
« Reply #28 on: 26 May 2008, 21:39:44 »
I don't know how much this will help but here's a list of Cadillac Catera suspension parts. The part numbers are mostly North American with a few British and European suppliers mixed in. Maybe your repair shop can cross reference them. I also have bushes, springs, etc. I can post the whole thing if you like. Remember, if it fits the Catera, it will fit the Omega. FYI: The has self leveling rear air shocks.
STRUTS & SHOCK ABSORBERS (incl: MOUNTS, BOOTS, and BUMP STOPS)
Koni Sport Struts & Shocks:
-Sport Strut: part # 8610-1315Sport (insert in OE strut; externally adjustable for rebound)
-Sport Shock: part # 80-2591Sport (non-air, must disable self leveling; rebound adjustment made before installation)
http://store.summitracing.com
Struts & Shocks: Sport ride.
BILSTEIN (Opel/Vauxhall)
-Strut - B4 Gas: part # VNE-4480 (OE Replacement)
-Shock Absorber - B4 Gas: part # BNE-2861 (OE Replacement)
-Strut - B6 SPORT: part # VE3-4178 (Firm)
-Shock Absorber - B6 SPORT: part # B46-2260 (Firm)
-Strut - B8 SPRINT: part # VE3-4426 (Firm/Lowered)
-Shock Absorber - B6 SPRINT: part # B46-2258 (Firm/Lowered)
-Boot & Bumpstop: part # ASP-C245 (front)
http://www.carparts-cat.com/pkw/parts/artliste.asp?SID=0000992458273793018004&ID=84,3466,3861,0,1,1,1&GID=854,171&NID=0,11,121
KYB GR2:
-Strut: # 334903
-Strut Mount: part # SM5285
-Shock Mount: part # SM5287
-Strut Boot & Bumpstop: part # SB101
http://www.shockwarehouse.com/index.cfm?mode=results&selected_model=3755&selected_year=2001
Strut only. OEM ride. No adjustments.
KW Automotive UK (Vauxhall Omega)
-KW Sport Suspension Kit/Lowering Springs & Dampers       #20060068
-KW Coil Overs (adjustable height/F&R)                   #10260025
-KW Coil Overs (adjustable height & rebound/F&R)             #15260025
http://www.kwsuspensions.de/uk/
Coilover shocks are usually for track use. May be too harsh for the street.
Monroe:
Sensatrac Strut: part # 71503 (Twin-tube low pressure gas unit similiar to OEM)
Max-Air Rear Shocks: part # MA825 (For use with self leveling)
Upper Mount: part # 903932
Front Boot & Bumpstop: part # 63619
ACDELCO Strut: part # 506592 {#09192250} Right / # 506591 {#09192249} Left
http://www.rockauto.com/
Factory Replacement w/o SPORT APPEARANCE PKG (RPO-TV5)
ACDELCO Strut: part # 506594 {#09192292} Right / # 506593 {#09192291} Left
Factory Replacement w/SPORT APPEARANCE PKG (RPO-TV5)
ACDELCO Part # 560227 {#72119084}
ABSORBER,RR SHK w/o SPORT APPEARANCE PKG (RPO-TV5)
Factory Replacement - Catera
ACDELCO Part # 560228 {#72119087}
ABSORBER,RR SHK w/SPORT APPEARANCE PKG (RPO-TV5)
Factory Replacement - Catera Sport
Gabriel Ultra Strut: part # G56769
http://www.gabriel.com
OE Catera replacement
Elvin
« Last Edit: 26 May 2008, 21:48:55 by elvin315 »
Is that all there is, is that all there is
If that's all there is my friends, then let's keep dancing
Let's break out the booze and have a ball, If that's all there is
Re: Front shocks
« Reply #29 on: 26 May 2008, 21:41:07 »
Cheers.
Least mine are nice and simple bog standard ones!  ::)
Pages: 1 [2] 3  All   Go Up
