Pages: 1 2 [3]  All   Go Down
Author Topic: Front shocks  (Read 10382 times)
Re: Front shocks
« Reply #30 on: 26 May 2008, 21:44:00 »
Albatross, if you want the back-end to be more stiff, might as well fit Blistens?
But i have heard they could be too hard, if you don't like the Elite setup, i would fit standard MV6 shocks. Which are not self levelling (SL)
Only need SL for pulling caravans or heavy loads.
Personally if i had a 3.2 Elite, and wanted less roll, i would just fit standard MV6.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #31 on: 26 May 2008, 21:44:19 »
does anyone have the part number for standard rear shocks to hand?
Non levelling shocks 90542942
Cheers.
Least mine are nice and simple bog standard ones!  ::)
And on TC too.
TuBy's new whipping boy.
Albatross
  • Bedford
  • An LSD & an S2000!
Re: Front shocks
« Reply #32 on: 26 May 2008, 22:02:18 »
Thanks for that Captain :y
So I think I need:
Front LH:      9192291
Front RH:      9192292
Rear MV6:      72119086 (Assuming I junk the self levelling)
Rear:      72119084 (Assuming I keep the self levelling)
I (WIM) have already adjusted the position of the mounting of the self-levelling sensor on the trailing arm since fitting the MV6 springs so I may get away with the self-levelling shocks.
TMX, who has a self-levelling MV6 saloon (mini-facelift) has kindly just shared his VIN and VRN numbers with me so I might be able to see what my local Vx stealers come up with for his car too.
I may just simply bow to TB and Tunnies superior knowledge and advice and junk the self levelling. I will NEVER EVER tow an effin' caravan as long as I have a hole up my ar$e.
Tunnie, can you buy Bilsteins that are the standard MV6 height or do they only do those that lower the car? I don't want it much, if any, lower than an MV6 to be honest.
« Last Edit: 26 May 2008, 22:07:09 by Albatross »
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #33 on: 26 May 2008, 22:04:50 »
Thanks for that Captain ;y
So I think I need:
Front LH:      9192291
Front RH:      9192292
Is there a problem with your rear shocks as theyre going to be the same as the self levellers I've given you the number for.
Re: Front shocks
« Reply #34 on: 26 May 2008, 22:07:51 »
So I think I need:
Front LH:      9192291
Front RH:      9192292
Whats the millage on yours Alba?
Mines on 110k now, although my shocks don't seam to be leaking, they are going to be past their best.
Main reason i am changing mine now, is i will be underneath the car doing the springs anyway, makes sense to change them now. As i will get the use out of them  :)
If yours has no more than say 85/90k miles, or you have problems with it, i would save the dosh for now  :y
Re: Front shocks
« Reply #35 on: 26 May 2008, 22:10:00 »
So I think I need:
Front LH:      9192291
Front RH:      9192292
Your dad's were pretty shot as well...
Albatross
  • Bedford
Re: Front shocks
« Reply #36 on: 26 May 2008, 22:10:57 »
I only know of a problem with my front LH shock from the tyre wear pattern, but I thought I'd do them all at once. There is logic to this for a couple of reasons.
I've just changed over to MV6 springs is one reason. The other reason is that my car seems to be about 15-20mm higher on the driver's side at the rear and I was wondering whether that was a sign that the shock on the rear near side was getting a bit tired so I thought I may as well do all 4 shocks at once to be sure.
My car has done 96K
« Last Edit: 26 May 2008, 22:22:23 by Albatross »
Re: Front shocks
« Reply #37 on: 26 May 2008, 22:13:08 »
So I think I need:
Front LH:      9192291
Front RH:      9192292
Hence doing mine now, its done almost 15k more miles.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #38 on: 26 May 2008, 22:25:01 »
So I think I need:
Front LH:      9192291
Front RH:      9192292
Mine were totally rubbered when I changed them today.
Albatross
  • Bedford
Re: Front shocks
« Reply #39 on: 26 May 2008, 22:49:33 »
Mine don't appear to be leaking, but look very like those pictures around the bottoms. Does that mean they're 'rubbered' too?
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Front shocks
« Reply #40 on: 26 May 2008, 22:58:41 »
The crud around the bottom is an accumulation of the shocker oil and general road dirt so I'd be thinking yours are on their way out too.
Albatross
  • Bedford
Re: Front shocks
« Reply #41 on: 26 May 2008, 23:02:10 »
That's that then; thanks for all the advice.
I need:
Front LH MV6:      9192291
Front RH MV6:     9192292
Rear MV6:          72119086
I think.
Tunnie, I'll bring them, a spare pair of hands and anything else useful with me on Sunday. I might bring round oil and filter and do that whilst I'm there too.
Pages: 1 2 [3]  All   Go Up
