Author Topic: Flood!!  (Read 2547 times)
psg150
  • London
Flood!!
« on: 26 May 2008, 14:58:06 »
Just been out for a spin in the wet (very wet here) and have a flood in the passenge side rear footwell and in the passenger side front footwell (thought not as bad).
Is there a common point of failure underneath the car, am I unlucky or is it a simple seal or weld job?
Any ideas?
Re: Flood!!
« Reply #1 on: 26 May 2008, 15:00:58 »
Could be blocked scuttle drains
Albus Dumbledore
  • Bergen, Norway
Re: Flood!!
« Reply #2 on: 26 May 2008, 15:01:26 »
I am wondering if there isn't a drain there somewhere, that can have clogged up :)
psg150
  • London
Re: Flood!!
« Reply #3 on: 26 May 2008, 15:03:44 »
Scuttle drains? Sorry to be dim but need expansion.. Would that cause flooding from beneath??
Thanks for the help.
Jay w
  • Plymouth/Poole
  • omega gone
Re: Flood!!
« Reply #4 on: 26 May 2008, 15:04:43 »
the scuttle drain will be blocked, this means the water is backing up and has got into the cabin via the heater.
simple to fix, look down by the pollen filter and you will see the water, at the bottom there will be a grommet, get something like a coat hanger and try cleaning out the grommet, this will stop it from happening again
Re: Flood!!
« Reply #5 on: 26 May 2008, 15:04:58 »
Look on here - http://www.omegaowners.com/forum/YaBB.pl?num=1206287560
There's one on the drivers side to - easier to see/get at.
« Last Edit: 26 May 2008, 15:06:13 by dbug »
psg150
  • London
Re: Flood!!
« Reply #6 on: 26 May 2008, 18:34:02 »
Thanks All!
Just unblocked drain - that's an awkward and messy job!!
Does anyone know why that water would end up in passenger footwells??
Re: Flood!!
« Reply #7 on: 26 May 2008, 19:49:57 »
As the scuttle is blocked, the water level rises until it reaches the air inlet for the ventilation/air conditioning, it then flows past the pollen filter and blower motor and enters the car. It then drips/flows down any available pipe/wire/metal fitting and ends up in the footwell.
With luck the blower motor is OK, but they have been known to be damaged by water, the pollen filter will eventually dry out, as will the carpets.
The soundproofing is, however , a b*****d, it holds water like blotting paper and takes an age to dry, and if NOT dried fully... stinks... :(
Some folks have cut out the wet soundproofing to dry, others have used de-humidifiers ... either way .. get it dry or it stinks.... :(
HTH
« Last Edit: 26 May 2008, 19:51:30 by entwood »
Martin_1962
Re: Flood!!
« Reply #8 on: 26 May 2008, 22:29:23 »
HTH
VAXing, open windows in the sun and deodorant stuff - 3 weeks. Flood water from last summer
bighed
  • Shropshire
Re: Flood!!
« Reply #9 on: 27 May 2008, 07:18:53 »
Is it just me or has anyone else noticed that when vaux carpets get drenched, when drying they smell like cat urine  :-/
