Author Topic: water in car  (Read 1436 times)
chris fisher
  • Coalville,  Leicester
water in car
« on: 30 May 2008, 17:14:16 »
Hello again
My  v6 omega has developed a water leak of epic proportions. :-?
The thing is the passenger side front and rear carpet is soaking wet, and smells of antifreeze.
Has this happened to any one else, if so what was the cause.
Regards
Chris Fisher  :)
Re: water in car
« Reply #1 on: 30 May 2008, 17:45:11 »
Hi Chris
If the water definately has anti freeze in it then I would say the heater matrix or pipe leading to it has sprung a leek, but first I would check this
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
Re: water in car
« Reply #2 on: 30 May 2008, 19:33:21 »
could it be screenwash /water from windscreen washers leaking into car due to blocked scuttle drain.?
mike213735
Re: water in car
« Reply #3 on: 30 May 2008, 20:07:42 »
That's where I would look. Blocked scuttle drain. Common fault and easy to check.
Thanks
Mike
chris fisher
Re: water in car
« Reply #4 on: 30 May 2008, 20:47:17 »
Thanks for that.. I will check the scuttle drains,
The idea of the heater matrix sound favorite, as the header tank needs toping up every day.. and the footwells are literally soaking wet.
Where abouts is the hbv, i'll have to get a haynes manual wont i, just get stuck in and sort it..
Is it a massive job to get to the heater matrix..
Chris.
Re: water in car
« Reply #5 on: 30 May 2008, 20:56:54 »
Chris.
Yup, fairly big, lot of work needed.
Could have been prevented by keeping the scuttle drain clear!
HBV is at the rear of the engine on the drivers side.... i think! don't own a V6, so forget which side it is.
chris fisher
Re: water in car
« Reply #6 on: 30 May 2008, 21:02:15 »
Thats the trouble isnt it..
only had the old girl for about a month.. and below the gloss and bullshit, if the last owner has'nt bothered we get to reap what they sow
Chris        :(
Re: water in car
« Reply #7 on: 30 May 2008, 21:05:15 »
HBV is behind engine (back of the v) under the scuttle,(remove, with wipers).3 water hoses  with metal clips(long handled long nose plyers), and a vac pipe on top. Pig to get at, feet off the ground job. You'll see. Never done heater matrix. Hope helps. Good luck with it.:-)
chris fisher
Re: water in car
« Reply #8 on: 30 May 2008, 21:09:55 »
Cheers chrisgixer, and every body else...
Like i said i'll get meself a manual and grt on with it, if i can find time ect ect
Chris fisher
Richie London
  • heathrow
Re: water in car
« Reply #9 on: 30 May 2008, 21:13:33 »
Chris fisher
got mine off amazon, 9.99 came in 2 days
richie
chris fisher
Re: water in car
« Reply #10 on: 30 May 2008, 21:25:34 »
thanks richierich, i'll order now
