Author Topic: leaking sunroof?  (Read 1869 times)
hol666
  • Lechlade, Gloucestershire
leaking sunroof?
« on: 28 May 2008, 20:14:06 »
Hi all, with all this lovely rain we've been having, I have a slight damp problem in my omega.  It is dripping from the drivers front corner of the sunroof straight onto the driver seat :-[
Is there a drain in the sunroof area and if so, where does it drain too?
Any help on this would be really appreciated, thankyou.  A wet seat is not comfortable when driving plus duct tape don't look good! :'(
Dazzler
  • Haverhill, Suffolk
Re: leaking sunroof?
« Reply #1 on: 28 May 2008, 20:17:41 »
There should be 4 drains, one in each corner its a tube which exits just behind the front wheels or just in front of the rear wheels.
Check to make sure these are clear ;)
« Reply #2 on: 28 May 2008, 20:20:28 »
Don't push anything too big down the holes, you risk dislodging the pipes, I blasted mine with an airline .. made a big difference. I was told to use a welding rod .. as apparently this is the right size ...... but chickened out.
hol666
« Reply #3 on: 28 May 2008, 20:26:10 »
right, one in each corner of the sunroof, fair enough many thanks for the quick replies guys :y
I'll also check/try to find the tails too! Thanks ;)
My guess is 'blossom' and those cherry sticks as I park near tree's both at home and work, I try to keep this stuff off the car but not easy!
« Last Edit: 28 May 2008, 20:28:11 by hol666 »
hotel21
  • The Kingdom of Fife
« Reply #4 on: 28 May 2008, 20:34:34 »
I have used one of those stretchy, white plastic covered net curtain rail thingys that the female of the species love to use on toilet windows (or at least, mine does).  Its strong enough while bendy enough to wriggle it down drain tubes to ensure they are clear.
Use an air line with caution.  A face full of stale soggy crud does not taste like fillet steak......    ;)
hol666
« Reply #5 on: 28 May 2008, 20:37:12 »
;D ;D very true, good idea about the curtain wire, pretty certain I can get hold of some, just hope the ex doesn't catch me though!  :o
hol666
« Reply #6 on: 31 May 2008, 18:24:09 »
 ;) thanks guys, the net curtain wire did the job nicely, well worth any omega owner with a sunroof having in the toolbox!  :y
