Author Topic: That's not right!!  (Read 5323 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: That's not right!!
« Reply #15 on: 31 May 2008, 17:47:59 »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
« Reply #16 on: 31 May 2008, 19:40:17 »
Code 19 is a sign of a failing crank sensor.
The 19 is actualy an incorrect signal indication, i.e. the signal is 'not what the ECU expects', which does NOT sudgest a poor connection or the thing being disconnected (you would get a 31 with the engine running in this case).
So, change the crank sensor but, look at the connector shape at the rear of teh plenum to know which type to get.
Sorry to disagree, but a v6 wouldn't run with a connection poor enough to cause a 31, or if it was disconnected ;)
Albatross
  • Bedford
  • An LSD & an S2000!
« Reply #17 on: 31 May 2008, 19:45:49 »
OK, have to confess my embarrasment since, as so helpfully pointed out above) the fault may have been there all along, but without having paperclipped it before I started we will never know.
Note to self...either do it properly in a logical sequence (like in those procedure documents I spend large parts of my day writing) or give it to someone else to do.
Worry not though, the crank sensor is not hard to change :y
It may be a relatively simple job to change, but do not be surprised if you end up having to simply cut as much as you can reach off each end of the cable from the one you're taking out. The way that they were fitted to the engine before it was dropped into the car is a bit a fault in my opinion and in most cases there is not a cat in hell's chance you're going to pull the old one through and out if it is the original one as was fitted at manufacture.
Leaving the residual (trapped) cable in there is of no consequence and the guide on here has useful advice on much better routing. Make sure you keep the new cable clear of the exhaust which is a common cause of recurring failure.
« Last Edit: 31 May 2008, 23:21:59 by Albatross »
