Author Topic: coolent leak dripping from bellhousing  (Read 5079 times)
bibbot
  • sutton sm39n
« on: 01 June 2008, 19:41:17 »
I have just done an oil cooler replacement but the bad news :'(
Is there is coolant dripping from the bottom of the bell housing
So where is it coming from?
There was a coolant lose before I did the oil cooler
I am thinking there are 4 possible
1 heater pipes
2 oil cooler plate
3 the bridge
4 the coolant outlet pipe just above the bell housing
The first 3 not to bad to do, but the outlet pipe seems impossible
To get to.
Has any one ever tried to use a small cam to look round the back and down to see where the leak is or maybe from underneath by putting the cam to the top of the bell housing.
Any ideas or comments will be most appreciated  thanks
Jay w
  • Plymouth/Poole
  • omega gone
Re: coolent leak dripping from bellhousing
« Reply #1 on: 01 June 2008, 19:43:31 »
Heater bypass valve, it is at the back of the engine and is generlly the biggest culprit
« Reply #2 on: 01 June 2008, 19:44:45 »
Is it a 1998 model?  ::)
bibbot
  • sutton sm39n
« Reply #3 on: 01 June 2008, 19:51:04 »
reg, on oct 97 mate
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 01 June 2008, 20:13:35 »
It does sound like hbv to me also, and as the car has been sitting on your drive for the best part of 18months it could well be fubared due to inacctivity and the seals inside may well be perished due to oil contaimination.  You will find it behind the left hand side head and you can get better access to it with the plenium removed. It has three pipes and one vac pipe on the top.
Gary.
Jaguar XJ6
bibbot
  • sutton sm39n
« Reply #5 on: 01 June 2008, 20:24:25 »
thank gary
where does the hbv actually leak Iv a small cam im going to see if i can see the leak with it first
steve
ffcgary1
  • Mitcham,Surrey.
« Reply #6 on: 01 June 2008, 20:36:22 »
It leaks from the main body of the valve where the top joins the body.
 No repair is poss and replacment is the only cure. use gen vx valves and make sure the part has the part no stamped on the top as a few without this were supplied to vx and failed within a few months.
« Last Edit: 01 June 2008, 20:41:38 by ffcgary1 »
Jaguar XJ6
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #7 on: 01 June 2008, 20:38:30 »
Think i have the same problem.... ahh! getting it soreted though  :)
« Reply #8 on: 01 June 2008, 20:39:48 »
You'll just have to drive around in your babe magnet before then :D
psychnurse
« Reply #9 on: 01 June 2008, 20:43:01 »
Thank you very much!!! Thought you were quite a nice bloke up untill now!!
« Reply #10 on: 01 June 2008, 20:46:39 »
Do you want your leak fixed?  [smiley=evil.gif] ;)
psychnurse
« Reply #11 on: 01 June 2008, 20:54:57 »
well i would loose the magnet then lol!! nah u aint a bad un!!!!  ;D
« Reply #12 on: 01 June 2008, 22:00:42 »
reg, on oct 97 mate
Hmmm, is last letter of VIN a W?
bibbot
  • sutton sm39n
« Reply #13 on: 01 June 2008, 22:46:06 »
just spent 2 hours setting up a cam and TV to have a look round the back and after many manifold burns I can say for sure it not the hbv
IV looked at the top of the bridge and no water coming from the left hand side of the oil cooler plate and I have looked down on to the coolant outlet pipe and is dry on the top
Is not so easy to get the cam down the right hand side
But I can see water not sure whether it sperting or pulse dripping from
Just where the oil cooler pipes disappear behind the back and up over the bellhousing
So it seam that is Cumming form the left hand side
Im going to make some sort of twisty handle so I mite get round the right hand side
« Last Edit: 01 June 2008, 22:55:40 by biblong »
bibbot
  • sutton sm39n
« Reply #14 on: 01 June 2008, 23:02:05 »
yes the last letter  of the VIN is a W
