Author Topic: fuel filter  (Read 2014 times)
paul52cdx
  • GLASGOW
fuel filter
« on: 01 June 2008, 14:31:08 »
Just changed fuel filter on my 2.2dti but it wil not start.
Do I need to fill the filter with diesel to prime.
Any help welcome
FRE07962128
Re: fuel filter
« Reply #1 on: 01 June 2008, 14:32:25 »
Any help welcome
Yes I believe you do need to prime system, just as you do if ever you run out of diesel. :y
paul52cdx
  • GLASGOW
Re: fuel filter
« Reply #2 on: 02 June 2008, 19:38:27 »
Primed it and had to give it a tow thanks for the help back on the road.
V8S
  • Dorset
Re: fuel filter
« Reply #3 on: 04 June 2008, 10:25:51 »
Hi Paul,
Can you tell me where the filter is and maybe how you went about changing it?
I have a saloon though so perhaps it is in a different place....?
Thanks.
Re: fuel filter
« Reply #4 on: 04 June 2008, 11:55:26 »
When changing a diesel filter you must fill it with fuel... Otherwise you will have problems starting like you did.
The Diesel engine needs priming... They are supposed to self prime, IIRCC, but need to be turned over a lot!! :y :y :y
paul52cdx
  • GLASGOW
Re: fuel filter
« Reply #5 on: 05 June 2008, 08:17:05 »
Hi the fuel filter is on the drivers side between the expansion tank and the bulk head. You will see two black pipes and a electric cable going into it. You can loosen the expantion tank buy removing the clip to the inner wing and pushing it towards the engine to free it. You will need a torque fro the top of the fuel filter.
After you have replaced it full the filter with diesel before starting, I did not at first and had to give it a tow to start will remember that one the next time.
regards
Paul
