Author Topic: Quite alarming  (Read 1509 times)
Leomas
  • Boyne Valley (on loan)
  • Ooops what did I break this time?
Quite alarming
« on: 05 June 2008, 10:46:16 »
Now here's a thing. Several times recently my alarm has gone off for no apparent reason, twice I have been close enough to see that no 'little gentleman' has been around to encourage it and this morning I was signing the postie's little book to accept a letter when it went off right in front of me.
The car is parked facing South so I wondered if it was possibly heat related? Clutching at any passing straw a bit here.
Recently 'learned up' and being more careful now, honestly.
Ummm except for where I fix one thing and break something else
Re: Quite alarming
« Reply #1 on: 05 June 2008, 10:51:03 »
Check the bonnet switch mounting bracket is not bent......you can unplug the switch to prove if this is the cause.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Quite alarming
« Reply #2 on: 05 June 2008, 10:52:04 »
disconnect the bonnet sensor or renew the bonnet sensor and see what happens!
the bonnet sensor lives strangely enough under the bonnet on the passangers side near the scuttle plate / pollen filters its a little stick thing with a ruber gator on it
they usually fail and cause these symptoms
