Author Topic: Rattle/Drone when first starting  (Read 3557 times)
perfferle
  • North Yorkshire
  • All cats are grey in the dark!
Re: Rattle/Drone when first starting
« Reply #15 on: 02 June 2008, 22:26:40 »
Hey, why dont you reach up under the left side wheel arch you will see and feel the air pump motor assembly. Feel arount the top of the motor body and remove the electrical connector - This disables the pump. I disconnected mine this evening and voalla: no more noise at startup. :y
BruceT
« Reply #16 on: 03 June 2008, 07:57:12 »
I started my car on the drive this morning. Didnt drive off. Reved the engine gently and the noise does get louder.
But, this drone stops far sooner than I thought, Literally within 1-2 mins. So must be the SAI pump.
Ill have a feel tonight for this plug.
1999 Omega 2.0 16v CD
JasonH
« Reply #17 on: 03 June 2008, 19:22:24 »
There is definitely a single fuse (F49, 50A) and a relay (K162) that live in the under bonnet fuse box that both only control the SAI in your car.
BruceT
« Reply #18 on: 04 June 2008, 17:22:20 »
Dont suppose you have a picture showing which ones it is?
JasonH
« Reply #19 on: 05 June 2008, 18:28:00 »
I had a good look - but I can't find a picture.
If you look in the under bonnet fuse box next to the battery I think it's the only 50A fuse in there.
