Author Topic: this might be a stupid question, sorry,  (Read 1881 times)
garbage456
  • Carshalton, Surrey
« on: 09 June 2008, 16:14:52 »
I got climate control in my miggy, now today is the first day it has been really hot, but with the temp set to 18,17,16 or LO, the air was just, well, cool to warm, should this not be freezing cold like an air con?
thanks
markey mark
  • SLady bitshorpe north lincs
Re: this might be a stupid question, sorry,
« Reply #1 on: 09 June 2008, 16:19:11 »
will be needing a top up matey !! kwik fit £44.95 if it dont work you dont pay !! :y
garbage456
« Reply #2 on: 09 June 2008, 16:23:21 »
seems cheap
markey mark
« Reply #3 on: 09 June 2008, 16:34:45 »
yea great deal !! :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 09 June 2008, 17:37:59 »
yes bnot rubbing salt in wounds but my mv6 on 19 and below is nice and ice cold try quik fit but dont bother with halfords!
« Reply #5 on: 09 June 2008, 18:03:41 »
yes but kwikfit bunch of to**ers - topped mine up despite a leak!! Ice cold until i got home (10 miles) then all refrigerant had escaped.  Got refund after mentioning trading standards and head office.  Knew i shouldn't have took a car in there.
markey mark
« Reply #6 on: 09 June 2008, 18:06:06 »
aye they certanly not technicians ;D ;D
FRE07962128
« Reply #7 on: 09 June 2008, 18:10:34 »
I agree!  I would advice anyone NEVER to use Kwik Fit if you value your car and your mental health!!
 :o :o :o :o :o
garbage456
« Reply #8 on: 09 June 2008, 18:14:06 »
 :o :o :o :o :o
where should i go then to get air con done?
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #9 on: 09 June 2008, 18:15:39 »
 :o :o :o :o :o
someone who specialises in air con.
yes they will charge more, but you have the piece of mind of knowing that it was done properly, and to me that is priceless
« Reply #10 on: 09 June 2008, 18:28:26 »
I took mine to Kwik Fit and they said I had a fault with the low pressure hose and there was no charge, so I called out a local Aircon specialist, he fixed the fault (bit of dirt in the Schrader Valve) and vaccumed the system then refilled it and its been brilliant in this weather :y
FRE07962128
« Reply #11 on: 09 June 2008, 18:30:37 »
 :o :o :o :o :o
This is absolutely the right advice!  I have always used local specialists (from Yellow Pages) wherever I lived and found them brilliant! :y
garbage456
« Reply #12 on: 10 June 2008, 11:16:54 »
had it done today, £59+ vat for re gas, £79 + vat for re gas and a service.
so did the £79 option !!!!
« Reply #13 on: 10 June 2008, 11:24:57 »
Just to add, I noticed an air con servicing machine at WIM at the open day. Might be worth enquiring. At least you can be 100% sure you're not going to get a  muppet working on your car there.
