Author Topic: Fault code 0340  (Read 3605 times)
John Lewis
  • Macclesfield, Cheshire
  • Macc is wack
Fault code 0340
« on: 06 June 2008, 16:04:34 »
Hi
Just done a paperclip test and I think it was 0034, can't find it anywhere though with a search. 10 flashes then 10 more, then 3 then 4.
EDIT: Solved this bit, just need to see if the parts terminally ill or soaked in oil.
Anyone care to elaborate?
Ta
J
« Last Edit: 06 June 2008, 20:16:10 by johnlewis »
Andyb
  • Lincoln
Re: Fault code hep req'd
« Reply #1 on: 06 June 2008, 16:16:33 »
what car m8
John Lewis
  • Macc is wack
« Reply #2 on: 06 June 2008, 16:29:03 »
<<--------1998/S 2.0 16v CDX saloon sir.
« Last Edit: 06 June 2008, 16:29:55 by johnlewis »
Andyb
  • Lincoln
« Reply #3 on: 06 June 2008, 16:37:09 »
http://www.omegaowners.com/forum/YaBB.pl?num=1207565474
but 34 is not listed have you checked it correctly
John Lewis
  • Macc is wack
« Reply #4 on: 06 June 2008, 16:39:34 »
Yeah I checked there too.
Gonna video it and post it up now I think.
John Lewis
  • Macc is wack
« Reply #5 on: 06 June 2008, 16:55:25 »
Actually I think in retrospect its 0340
P0340      Camshaft Sensor Incorrect Signal
hmm
Vid here
http://www.youtube.com/v/pfs8BFyaWOc
Does this indicate a failure, or could it be coated in oil from my rocker cover?
« Last Edit: 06 June 2008, 18:36:56 by johnlewis »
rickyboy
  • Glasgow
Re: Fault code 0340
« Reply #6 on: 07 June 2008, 11:27:19 »
Only one way to find out...  Take it off and have a look.  I bought my car with an array of fault codes and it turned out to be a dirty camshaft sensor.  Make sure the sensor and it's mating faces are all clean and with any luck the code will disappear.
If not, then the sensor will probably need replaced.  Has the timing belt been changed recently?
John Lewis
  • Macc is wack
Re: Fault code 0340
« Reply #7 on: 07 June 2008, 15:18:13 »
Yes cambelt kit done about 1k ago. Also the cam cover and gaskets have been replaced a week ago, as it had been leaking oil for quite some time - well over 3 months, because I've had it that long.
I didn't know anything about Omegas when I bought it, but its definitely been a bit neglected for its mileage (68k). I just ordered a new Siemens camshaft sensor to be on the safe side, it was only about 19 quid delivered from Vauxparts, should be here Monday/Tuesday. Reckon its easy enough for me to fit? How do you get to it, thru the engine bay?
Ta
Re: Fault code 0340
« Reply #8 on: 07 June 2008, 16:00:53 »
0340 is cam sensor, and is prone to failure on 2.0/2.2
Genuine one does seem slightly more reliable than pattern
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Fault code 0340
« Reply #9 on: 07 June 2008, 18:07:17 »
Ta
Cancel it if you can and buy a genuine one from your Vx dealer.
« Last Edit: 07 June 2008, 18:08:12 by Auto_Addict »
I like red cars
John Lewis
  • Macc is wack
Re: Fault code 0340
« Reply #10 on: 08 June 2008, 14:29:36 »
Why whats the difference, apart from a royal shafting on price from Grasmere?  ;D
Sorry ignore that, just read the post above!!
I'll live with the pattern one for now, still trying to work out whether the cars viable with the amount of problems I've had with it thus far.
(reckon so)
« Last Edit: 08 June 2008, 14:31:29 by johnlewis »
Re: Fault code 0340
« Reply #11 on: 08 June 2008, 14:31:13 »
Some of the pattern ones have been known to either not work at all, or fail even more prematurely than the genuine ones do.  Cam sensors do seem to be very troublesome on the 2.0/2.2
John Lewis
  • Macc is wack
Re: Fault code 0340
« Reply #12 on: 08 June 2008, 14:32:58 »
Ah i see.
Well tell you wot hows about I clean this one out, cancel the other one and see what happens?
My car conked out 6 times in under a mile yesterday, its completely fooked. Every time I slowed down it just died, no power whatsoever.
EDIT: Could this solely be my camshaft sensor, or poss HT leads too?
« Last Edit: 08 June 2008, 14:36:57 by johnlewis »
Re: Fault code 0340
« Reply #13 on: 08 June 2008, 14:43:37 »
if you are getting a 0340, then ecu ain't happy with cam sensor. Unlikely to be HT.
Vaux did release a bulletin about the cable routing, suggesting unpicking loom and moving away from alternator.
As to which sensor to buy, you pays your money and takes your choice....
John Lewis
  • Macc is wack
Re: Fault code 0340
« Reply #14 on: 08 June 2008, 14:53:26 »
Fair enough, that seems way out of my depth, I'll get someone else to do it I reckons (cable routing that is)!
So where do I find said camshaft sensor and is it easy to remove/clean?
« Last Edit: 08 June 2008, 14:55:22 by johnlewis »
