Author Topic: very hot engine  (Read 4471 times)
andyroo
  • leics
very hot engine
« on: 03 June 2008, 16:49:28 »
hi, i eventually took all your advice and have bought a 2.5L V6 CD VERSION 1998, when i run it the fan comes on really quick and the engine seems very hot, temp guage runnung about 90-95 , im not losing any water , any ideas or is this normal on omegas
cheers
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: very hot engine
« Reply #1 on: 03 June 2008, 16:51:11 »
I think that's normal for a V6.
Someone will confirm, or contradict ;D
I like red cars
FRE07962128
Re: very hot engine
« Reply #2 on: 03 June 2008, 16:52:45 »
Yes that IS perfectly normal for a 2.5 V6. :y
andyroo
  • leics
Re: very hot engine
« Reply #3 on: 03 June 2008, 16:53:25 »
cheers, i will see if any more responses, also meant to mention it smells hot if that makes sense,
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: very hot engine
« Reply #4 on: 03 June 2008, 16:54:49 »
FRE07962128
Re: very hot engine
« Reply #5 on: 03 June 2008, 16:58:56 »
Engines fully heated up do,  but as long as there is not a strong smell of oil or smoke/steam showing anywhere, that should be perfectly ok. :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: very hot engine
« Reply #6 on: 03 June 2008, 16:59:53 »
Agreed
I like red cars
andyroo
  • leics
Re: very hot engine
« Reply #7 on: 03 June 2008, 17:00:13 »
smells hot not an oily smell but faint hint of burning smell, know i sound a plank but difficult to describe   :-/
andyroo
  • leics
Re: very hot engine
« Reply #8 on: 03 June 2008, 17:02:46 »
ok cheers, just not had a car that heats up so quick before, is it worth doing a coolant change ?? , dont know when last one was done.?? :-/
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: very hot engine
« Reply #9 on: 03 June 2008, 17:04:00 »
Monitor it for a couple of days, and report back.
I like red cars
FRE07962128
Re: very hot engine
« Reply #10 on: 03 June 2008, 17:05:19 »
[/highlight]
I would Andy.  It is a cheap way of ensuring the mix is right, and it is all as it should be from a date you will be aware of. :y
FRE07962128
Re: very hot engine
« Reply #11 on: 03 June 2008, 17:07:00 »
......in addition Andy.....;do you know when the cam belt / tensioners / water pump where last changed?
If it was 40k miles ago or more they need changing. :y
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: very hot engine
« Reply #12 on: 03 June 2008, 17:07:49 »
If you change the coolant, make sure you use genuine VX antifreeze with a 50/50 mix.
I like red cars
andyroo
  • leics
Re: very hot engine
« Reply #13 on: 03 June 2008, 17:08:27 »
will do , cheers :y do you know if you can easily change the air con button and heated seat button on dash as they are worn, also bulb behind speedo gone is that an easy fix :-/
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: very hot engine
« Reply #14 on: 03 June 2008, 17:09:22 »
Coolant change will do it no harm at all. you need a 50/50 mix for compleat protection, and as you have no idea when it was done last you should do it. use vx pink coolant and be advsed that if yo drain via the rad drain you will only get about  50% of the old stuff out. so flush out well untill the water is clear, then add about 5.5ltres of pink coolant  to the system. job done. :y
Jaguar XJ6
