Author Topic: Strange Light  (Read 1278 times)
coronaryman
  • Halesowen West Midlands
Strange Light
« on: 09 June 2008, 18:32:46 »
Hi All
Just driven back up the M5 following a blisteringly hot few days
in Perranporth in Cornwall.
Took it steady on the way back as the outside temp was at times reading 33 degrees. (Mental note must get aircon fixed). Got back
close to home and decided to top the diesel up at the local garage.
When I fired the beast up again I had the warning light next to the
ABS light illuminated and seemed to be limited to about 3,000 rpm.
Not sure what the light is for as cant find my handbook at the moment.
Pulled over and switched off and on. When it fired up again all dash warning lights out as they should be but ran for about 2 seconds and cut out. Fired it up again and all seems ok. Any ideas? could it just be the heat or because I had just come off the motorway non stop from Cornwall? Shall I phone the scrapyard now? :'(
Best Regards
Mike
Taxi_Driver
Re: Strange Light
« Reply #1 on: 09 June 2008, 20:06:07 »
Was it symbol of engine? If so thats the EML on yours (Engine management light) You need to get the codes read for diagnosis.......not sure of you can paperclip a tractor tho  :-/ might have to be tech2 job or cheapo tech2  :-/
Just noticed your in the Midlands.........not too far away from Jaime (TheBoy) he can tell you what the ecu's complianing about with his Tech2  :y Give him a PM  ;)
« Last Edit: 09 June 2008, 20:08:41 by Taxi_Driver »
VX1
  • Reading, Berkshire
Re: Strange Light
« Reply #2 on: 09 June 2008, 20:09:55 »
You can do the paperclip test but just make sure you have the car running. Read the codes and post on here. It may be the crankshaft sensor or the camshaft sensors at fault BUT paperclip it first.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
coronaryman
Re: Strange Light
« Reply #3 on: 10 June 2008, 19:23:02 »
O.K. Just about to do the paperclip test.
Might sound a stupid question but do I insert the paperclip
before or after starting the car?
All those electrics look a bit expensive so better to be safe than
sorry! :-/
Best Regards
Mike
Re: Strange Light
« Reply #4 on: 10 June 2008, 19:25:27 »
Not all TDs are paperclipable.  How old is the car?
coronaryman
Re: Strange Light
« Reply #5 on: 10 June 2008, 23:42:27 »
Registered Feb 1998 on an R reg
Best Regards
Mike
