Author Topic: Low Beam Fld/Vision ???  (Read 4289 times)
Re: Low Beam Fld/Vision ???
« Reply #15 on: 10 June 2008, 21:18:14 »
Right Ive just tried bouncing the car and I can't hear anything apart from a small ticking noise coming from the air filter housing or at least I think thats what it is - big black box just behind o/s headlamp unit.
Could it be something as simple as a fuse?
If its not the sensors, it will most likely be a fubar servo.  Is one light higher than the other?
Scania
  • leighton buzzard
« Reply #16 on: 10 June 2008, 22:29:29 »
I think so but I'm not 100% certain - Why, does this sound bad/expensive?
« Reply #17 on: 10 June 2008, 22:34:06 »
Pop up to Brackley one day, we can pop tech2 on it and tell you what you need to do.
Scania
  • leighton buzzard
« Reply #18 on: 10 June 2008, 22:49:27 »
I can only make it at the w/ends is that ok?
« Reply #19 on: 11 June 2008, 19:00:36 »
Yup, if I'm often about at weekends...
Scania
  • leighton buzzard
« Reply #20 on: 11 June 2008, 20:44:34 »
PM sent
