Author Topic: climate control panel  (Read 4989 times)
Andyb
  • Lincoln
Re: climate control panel
« Reply #15 on: 12 June 2008, 16:37:48 »
could it be the resistor pack on the side of the heater unit
Beconboy
  • DAGENHAM
    • 2000 3.0 OMEGA ELITE
« Reply #16 on: 12 June 2008, 17:26:21 »
went out there today had the panel out again and found that the sampler fan was jammed for one and also after changing fan
found the yellow multi plug was loose and not making contact
rectified that and every thing seems to be hunky doori :yexept
when you turn ignition off you still get little straight lines coming up
can that be taken out by tech 2 later? and thanks for all the response to this thread
                      GARY :y
« Reply #17 on: 12 June 2008, 17:28:36 »
                      GARY :y
If its working, I would suspect they are old codes. Not sure if they clear on their own after a while, or if they need to be cleared with Tech2
« Reply #18 on: 12 June 2008, 17:29:26 »
And, if you were thinking of ABS meet, I don't think I can make the one on the 4th July :(
« Last Edit: 12 June 2008, 17:29:51 by TheBoy »
Beconboy
  • DAGENHAM
« Reply #19 on: 12 June 2008, 17:32:41 »
lol would i do a thing like that tb ican wait till the 27 july at wim
gary ;D
« Reply #20 on: 12 June 2008, 17:34:53 »
gary ;D
True, if I take it there...
Beconboy
  • DAGENHAM
« Reply #21 on: 12 June 2008, 17:37:35 »
 :'( oh go on pretty please :P
« Reply #22 on: 12 June 2008, 17:57:27 »
I need to check with WIM first - I don't what to distract from what they are trying to show us...
Beconboy
  • DAGENHAM
« Reply #23 on: 12 June 2008, 18:19:14 »
yer i understand just that i,m being a selfish bugger ;D :y
