Author Topic: locking help  (Read 1899 times)
V6drift
  • rotherham
locking help
« on: 13 June 2008, 19:42:35 »
i need some helpful advice on my central locking please,
if i lock and unlock the drivers door using the key, everythings fine,
but when using the remote, the drivers lock wont lock or unlock but the others do,
what is it most likely to be???
omega drivers do it sideways...
Re: locking help
« Reply #1 on: 13 June 2008, 19:45:28 »
If it's just the one door it sounds like a solenoid.  Maybe just needs the door panel off and lubricating.  :y
V6drift
  • rotherham
Re: locking help
« Reply #2 on: 13 June 2008, 19:54:56 »
ive got the door panel off,
what and where do i lube up???
Re: locking help
« Reply #3 on: 13 June 2008, 20:02:16 »
Not sure matey, never done one, thought I had seena thread on the same fault but cant find it at the mo.
All I have found so far is this.
http://www.omegaowners.com/forum/YaBB.pl?num=1152618707
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: locking help
« Reply #4 on: 13 June 2008, 20:08:57 »
Exactly the same happened to mine .... drivers door wouldnt lock or unlock using fob but was fine with key .... Vx replaced the door motor at a cost of £135 ... luckily it was covered by my warranty  ;)
V6drift
  • rotherham
Re: locking help
« Reply #5 on: 14 June 2008, 08:24:33 »
i forgot to say that this is an intermitant fault,
doesnt work 99% of the time but occasionally does,
any more ideas? and does anyone have the parts to fix it?  :y
rickyboy
  • Glasgow
Re: locking help
« Reply #6 on: 14 June 2008, 09:47:47 »
Exact same has happened on mine.  It started as an intermittent fault but doesn't move at all any more.  Think the motor or solenoid needs replaced.
You can lubricate the solenoid and it will help for a while.  It's the black plastic part with a white top which is connected to the locking rod.  Slip back the rubber gator and lift the rod up and down while spraying in a lubricant.
willyboy
  • Leeds. West Yorks
  • Can Do !!
Re: locking help
« Reply #7 on: 14 June 2008, 10:17:19 »
Yup it starts off intermittent then totally stops working had one replaced wasnt too much, but 5yrs later same again (hell 5yrs) didnt realise it was that long ago..only just finally stopped working so its the key only for me for a while till I have time to fix it !
V6drift
  • rotherham
Re: locking help
« Reply #8 on: 14 June 2008, 20:07:35 »
thanks guys, its fixed (for now)  ;)
i pulled the rubber back and lubed it up then caked it in white grease  ::)
the motor that is  ;D
