Author Topic: gearbox error  (Read 10719 times)
    • Grandland 1.5 diesel
Re: gearbox error
« Reply #15 on: 01 April 2021, 18:01:43 »
I assume this is an April Fool’s post. If not this idiot is doing 115mph on a road somewhere near you! >:(
In third gear!  ;D
Diesel till I die
Re: gearbox error
« Reply #16 on: 04 April 2021, 14:37:03 »
In third gear!  ;D
The superior 3.0l auto would do 129mph in third.  Apparently.
To the OP, are you reading the TCM, or the engine for codes. They are different ECUs.
annihilator
  • Wirral
    • Omega Tourer V6
Re: gearbox error
« Reply #17 on: 04 April 2021, 15:14:16 »
It's a thread from 2008  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
Re: gearbox error
« Reply #18 on: 04 April 2021, 15:25:34 »
recycling is all the rage now
why use a new thread when there's one sitting dormant  :D
Re: gearbox error
« Reply #19 on: 04 April 2021, 16:43:16 »
Probably forgot his log in...
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: gearbox error
« Reply #20 on: 04 April 2021, 19:31:06 »
My 3.2 use to do this, floor it of the lights or were ever with sport mode in, fault code would flash up,, cured it by not using sport mode, and mine had 3.0L downpipes fitted.
Hoof'land storeman.
Smiler174
  • Orpington Kent
    • 2.6 v6 Omega
Re: gearbox error
« Reply #21 on: 10 April 2021, 12:46:37 »
Update to my problem, sports mode does not display on dashboard anymore and Car is very slow to move from a standing start and need to engage gears 1,2 and 3 to drive away. Last night whilst navigating some fierce road hump sports mode lit up on dashboard and dove as normal in drive for about an hour. Sports mode stopped working again and I suspect problem is between auto gear shift lever/button and gearbox wiring. How do you remove gear shift lever to change or fix. Any help much appreciated
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: gearbox error
« Reply #22 on: 10 April 2021, 13:13:24 »
What is the gear selector light doing, is it flickering about or is it stable on the selected gear?  Could be the gear selector switch on the side of the gearbox needs cleaning.  :-\
The poor acceleration in Drive is the gearbox in limp mode, hence why 1,2 and 3 work ok manually.
biggriffin
Re: gearbox error
« Reply #23 on: 10 April 2021, 14:12:32 »
 So what your saying is, follow the handy guide, in the relevent section within the forum, on how to remove and clean the selector switch.. :o
Hoof'land storeman.
YZ250
Re: gearbox error
« Reply #24 on: 10 April 2021, 14:18:28 »
I was getting to that bit.   ;D
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: gearbox error
« Reply #25 on: 11 April 2021, 13:17:40 »
Also very similar symptoms to if the snow button was pressed .could be connected ? . Faulty ?
Again this is also dependant on wether this is an April fools joke that has been carried on too long or as mentioned also someone who thinks driving at over 100 mph is acceptable !
Personally I'm fed up to my back teeth of the amount of people who blatantly break the 20 mph limits around by me and not by a few mph either !
Nuff said or il go into victor mode !
