Author Topic: What tank size for lpg conversion?  (Read 3928 times)
Re: What tank size for lpg conversion?
« Reply #15 on: 15 June 2008, 22:23:01 »
i would of offered it here first but nobody seemed interested in doughnut tanks due to the "perceived"issues with light bulbs.all omega saloon wheel wells are identical.
presume you mean it was a bit close to light clusster??? was that the case?
« Reply #16 on: 15 June 2008, 22:25:27 »
yes
sassanach
  • trowbridge
« Reply #17 on: 15 June 2008, 22:25:51 »
yup thats what its all about.
« Reply #18 on: 15 June 2008, 22:47:08 »
so its not possible to change bulb without removing tank? surely its not removable on a flexable hose?  :o
sassanach
  • trowbridge
« Reply #19 on: 15 June 2008, 22:53:12 »
its not that bad,with the right tools you can remove the cluster with the tank in situ,or unbolt the strap holding the tank down and "lean it"away from the cluster thus gaining access.how often do you change your light bulbs?
JueV6
  • Kent
« Reply #20 on: 15 June 2008, 23:08:17 »
I would have had that tank, my boot lock somehow fell apart and had to get in through the back seats, trying to remove the tank mounts and taking off the boot panel, IT WASN'T easy or fun, good job i can see the funny side NOW!!!! ;D ;D
btw mines 70lt and fites between the rear turrets.
« Last Edit: 15 June 2008, 23:09:27 by Juedu2 »
« Reply #21 on: 15 June 2008, 23:24:47 »
Aha so its all doable then, my old cdx had a prob. with wear on lead bit on the end of the bulb, bulb had not blown but was not giving a good contact, so i was in and out of cluster more than i would like. But i think that answers my questions. Thanks for your time gents. cheers :y :y
unless anybody has more info??
« Last Edit: 15 June 2008, 23:26:07 by chrisgixer »
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #22 on: 16 June 2008, 22:41:53 »
I've got a 90l across the back of mine..or is the Estate wider between the arches?  Can still lift up the wheel flap as well..just!
I might have been able to squeeze a 100l in there if my dad hadn't sold it to the bloke across the road  ;D
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
