Author Topic: ABS warning light  (Read 1750 times)
ABS warning light
« on: 20 June 2008, 22:50:34 »
Can anyone tell me ,does the ABS warning light in my revcounter on my 2.6CD also act as the low brake pad warning light as i cannot find a seperate light for low brake pad wear .Also Does the brake pad warning include all four wheels or only the front.
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: ABS warning light
« Reply #1 on: 20 June 2008, 22:57:33 »
vectras and omegas dont have brakepad warning lights instead they do it via the MID fuel computers check control
and on my mv6 and vectras there is only one sensor on the front pads and none on rear
« Reply #2 on: 20 June 2008, 22:58:43 »
I think the brake pad warning is only on one front wheel on the 2.6 and it should display on the MID IIRC
« Reply #3 on: 20 June 2008, 23:01:48 »
Do you mean the same panel that flashes low coolant and washer bottle etc etc
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 20 June 2008, 23:17:21 »
yes same , all thinks like pads,oli level etc come on MID display
« Reply #5 on: 20 June 2008, 23:29:02 »
Pad warning comes up on MID/GID/CID display. TID equipped cars do not have warning.
Up to 2001, there is a wear sensor on the inboard pad of both front wheels. 2001 and later, just one sensor on NSF inboard pad.
« Reply #6 on: 20 June 2008, 23:40:35 »
washer level, oil level( i've read) on mid, so presume wear level would be same My 99 cdx had 2 sensors on fronts,none on rear,1 one each on outside(?) pad, you should be able to see the wires attached to wheel arch to caliper, not to be confused with zenon sensor wire if tou have them. hope helps. :y
must type faster. :-X
 ps be ware breaking the sensor, they are ceramic and break easy >:(
« Last Edit: 20 June 2008, 23:41:59 by chrisgixer »
« Reply #7 on: 21 June 2008, 00:13:20 »
Up to 2001, there is a wear sensor on the inboard pad of both front wheels..................
Surely the OUT board pad. ie the one you see/get at when the wheel is removed? :-?
Taxi_Driver
« Reply #8 on: 21 June 2008, 09:02:31 »
No, should be the inboard pad, as the inner pads tend to wear faster...  :y
« Reply #9 on: 21 June 2008, 09:25:02 »
No, inboard pad(s)
« Reply #10 on: 21 June 2008, 10:30:07 »
No, inboard pad(s)
Memory must be failing me!  :y
