Author Topic: Rubber Seal  (Read 1152 times)
amba
  • Medway towns
    • German V6
Rubber Seal
« on: 25 June 2008, 14:10:27 »
Where the filler neck connects to the nearside cam cover there was ?? a seal.Looks like mine has started to weep as have oil from joint.
Can you get the seal or is it better with "black cam cover sealant"..a part number would be perfect if a seal does exist.
Thanks
Re: Rubber Seal
« Reply #1 on: 25 June 2008, 14:22:11 »
Thanks
You can get the seal as a single part and its the same item on the base of the filler neck as it is on the oil filler cap.
amba
  • Medway towns
    • German V6
Re: Rubber Seal
« Reply #2 on: 25 June 2008, 14:25:02 »
Thanks Mark.
I have found part # 90448217..so its worth changing when cam covers are done.
Page created in 0.044 seconds with 20 queries.
