Author Topic: cam sensor  (Read 1080 times)
spudboy
  • norwich
  • life is like a potato
cam sensor
« on: 25 June 2008, 12:42:45 »
Hi was hoping someone can tell me where to find the cam sensor on a 2.o r-reg,changed the crank sensor on monday but the eml is still coming on with a dip in the revs so guess it may be the cam sensor,so want to change that to any help will be great,
    cheers
Re: cam sensor
« Reply #1 on: 25 June 2008, 13:32:12 »
its right at the front, near the cams, should see a wire going into it right at the front of the ecotec strip.
You need to take the cam cover off, there is a tiny bolt holding it in, sits between the cams.
rickyboy
  • Glasgow
Re: cam sensor
« Reply #2 on: 25 June 2008, 16:52:43 »
And take the ecotec strip (spark plug cover) off and unplug the sensor first.
A simple clean of the sensor and it's mating surface often fixes the problem, so cheaper to give that a go first rather than buying a new one.
« Last Edit: 25 June 2008, 16:54:23 by rickyboy »
