Author Topic: rear wheel bearing  (Read 1953 times)
psnimv6
  • tyrone n ireland
rear wheel bearing
« on: 21 June 2008, 13:31:56 »
hello people my car just failed its mot on excess play in the near side rear wheel bearing ,my question is can the wheel bearing be adjusted or is it replace only ?i have not looked at it so i don,t no very much about it but the wheel bearing is making no noise but has a lot of play in it any info apprecated
Re: rear wheel bearing
« Reply #1 on: 21 June 2008, 14:39:21 »
In theory they are not adjustable.
Worth a quick check to make sure the hub nut is tight though as they are not that easy to change.
psnimv6
  • tyrone n ireland
« Reply #2 on: 21 June 2008, 15:25:16 »
thanks mark will check that ,anyway what is involved in changing them are they pressed in ? what price are they at stealers ? or would pattern be ok, the car has only 52000 miles on it so hopefully it might just need the center nut tightened
« Reply #3 on: 21 June 2008, 15:29:32 »
Retail Price / Normal Trade / Trade Club
Wheel Bearings, Rear
All saloon models 90510542 £42.75 £36.34 £25.99
All estate models 90486468 £61.50 £52.36 £37.13
psnimv6
  • tyrone n ireland
« Reply #4 on: 24 June 2008, 14:45:25 »
hi i just removed the rear drum and caliper and can see no centre nut :o am i missing something or has the bit that the wheel bolts to have to come off first ? if so how as it seems to be pressed on any info appreciated
« Reply #5 on: 24 June 2008, 15:02:36 »
On the front of the hub is a metal round cover, pop that off and the nut is behind it.
psnimv6
  • tyrone n ireland
« Reply #6 on: 24 June 2008, 15:07:09 »
youi mean the sort of light dust cap ? if so there is nothing behind it be a 1.5"-2" space , it has a sort of shape at both sides as if it is mean,t to be turned by a special tool or something  :-/
« Reply #7 on: 24 June 2008, 15:11:43 »
No, its me going scenial.....been working on to many font wheel drive cars!
You needs to pop the drive shaft off the back of the hub (6 bolts) and then you will see the hub nut......its a tight bugger, about 300Nm!
psnimv6
  • tyrone n ireland
« Reply #8 on: 24 June 2008, 15:28:32 »
thanks for that i will have another look tomorrow and see if it is tight if not will get a new one in as it has huge amount of play` in it
psnimv6
  • tyrone n ireland
« Reply #9 on: 26 June 2008, 08:51:34 »
just an update new bearing fitted yesterday so all is well again as for fitting and more important removing not what i would recommend to take on at the side of the house it is a fairly involving and time consuming job to say the least but got it sorted in the end :y
