Author Topic: face lift centre arm rest, lower button?  (Read 4017 times)
Re: face lift centre arm rest, lower button?
« Reply #15 on: 26 June 2008, 20:03:41 »
 ;D*goes for a look at this hitherto unnoticed beacon of gadgetry*
Can't find out what it does... *looks in handbook*
"To lower armrest fully - press the button on the bottom"...
;D ;D ;D ;D ;D ;D ;D AND its got its own bottom!
« Last Edit: 26 June 2008, 20:05:33 by chrisgixer »
weeman
  • lanarkshire
« Reply #16 on: 26 June 2008, 22:20:27 »
its the same as my 2.2 cd, for some strange reason its an optional center arm rest thats supposed to sit in the upper possition then press the lever and drops down to the lower possition. my nose got the better of me and i removed the center console to see what the problem was if any.
weirdly it has all the bells and whistles already in place but theres a sort of alloy cam and lever set up each side of the arm rest where the cams look as though the final machining has not been done the allow this wonderful event to take place :-X
i was going to set about them with a angle grinder but couldnt be bothered ::)
im glad i didnt now it could have deployed the ejector seat!! :)
FRE07962128
« Reply #17 on: 26 June 2008, 22:25:36 »
top button opens the lid, but bottom button does not seem to do anything, not used one before and only had car a month. A was assuming it would adjust the hight?
I suppose the mech. is buggerd? Whats the normal operation please guys? And is it likely to break again, if i lean on it to heavy. Tar
Face lift 3.2 elite 52 plate.
The bottom button is for activating a nitro system when installed. :y
 Why are you surprised?  You have everything else on an Elite, so why not!  ;D ;D ;D ;D ;D ;)
« Reply #18 on: 26 June 2008, 23:58:59 »
 does anyone know where the safety is for the ejector seat? I dont want to launch myself and box of tools all over close while i fix the beacon of gadgetry. Neighbours will moan about the mess :-/
« Reply #19 on: 27 June 2008, 00:11:53 »
 No? Maybe ill ask the parts man how to disarm the explosive bolts when i enquire about the correct machined techno wizardry. Sorry, beacon of gadgetry :y
