Author Topic: Do injectors ever fail?  (Read 1635 times)
magnul
  • Trondheim, Norway
« on: 30 June 2008, 06:59:16 »
On my way to work this morning the EML lit and the car was running like sh*t. Paperclip told me "26 Injector valve 2 Voltage high".
Do injectors ever fail, or is it more likely that there's an open circuit somewhere?
Re: Do injectors ever fail?
« Reply #1 on: 30 June 2008, 08:41:42 »
More likely to be the wiring, check the wires in the engine wiring loom tray
magnul
  • Trondheim, Norway
« Reply #2 on: 30 June 2008, 08:49:16 »
Will do during lunch hours. The loom is a bit of a mess because of the piggyback system between injectors and loom tray (car running on ethanol). Chances are that I upset something the other day when cleaning out the breather jet.
Will also check that the injector resistance is in the 14-16ohm area.
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 30 June 2008, 10:13:07 »
Have a good look at the multiplug for the injectors, the wires break close to the plug.
The last one I repaired broke so close to the connector that there was no room for heatshrink so I soldered the joint and then used a wrap of selotape as a mould and filled it with araldite to stop any others breaking.
magnul
  • Trondheim, Norway
« Reply #4 on: 30 June 2008, 11:27:23 »
Solved. One loose connector from the piggyback system.
« Reply #5 on: 30 June 2008, 12:36:59 »
Nice one .. easy fixes are always the best (and cheapest!!)
 :y :y
