Author Topic: Replica Spitfire  (Read 2077 times)
Replica Spitfire
« on: 24 October 2007, 10:46:46 »
 Ive just read this
The distinctive silhouette against the clouds and the spinetingling roar of its engine caused thousands of young boys to look skywards.
Many dreamed of one day flying a Spitfire, the aircraft credited with helping to win the Battle of Britain.
Now, more than 60 years after its starring role in World War II, anyone with £130,000 in loose change and a double-garage can have their very own version of the iconic fighter plane.
Already 22 of the almost life-size aluminium kits have been snapped up by flying enthusiasts eager to experience the thrill of piloting the world's most famous fighter plane.
Echoes of the past: The new spitfire flies past the white cliffs of Dover
The 90 per cent scale Supermarine Aircraft Mk 26 Spitfire kits cost £100,000 and need up to 1,200 hours and a further £30,000 to complete.
Powered by a GM V6 engine, the sleek aircraft can fly at speeds of up to 222mph and reach altitudes of 18,000ft.
With 700 hours of construction work already completed, the Australianbuilt kit is shipped to customers with all major components already formed. They must then spend a further two years fitting together the hundreds of parts.
Businessman and Spitfire fan Kieran Padden, who imports the model Spitfire, says demand for the ultimate boy's toy is on the rise, with four more orders on the books.
Imagine the crank sensor packing up on this :o
« Last Edit: 24 October 2007, 10:48:47 by Elite_Pete »
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Replica Spitfire
« Reply #1 on: 24 October 2007, 10:53:13 »
OR the Oil Cooler/HBV going mid flight  ;D
Humbugs...
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #2 on: 24 October 2007, 13:48:57 »
Or the leaking rocker cover gaskets dripping lube on the spectators below :D
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #3 on: 24 October 2007, 13:57:05 »
A high maintenance aircraft then!! ::) ;D
« Reply #4 on: 24 October 2007, 13:59:37 »
flying miggy is a bad dream  ;D
much better on the ground..
« Last Edit: 24 October 2007, 13:59:52 by cem_devecioglu »
Markjay
  • London
« Reply #5 on: 24 October 2007, 16:13:25 »
I wonder what's the MPG on this...?  :o
Alas, no more Omegas....
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #6 on: 24 October 2007, 17:32:10 »
Semi-synth 10/40?
I like red cars
Ken T
  • Stockport
« Reply #7 on: 25 October 2007, 19:21:34 »
It looks very nice, but I doubt the performance will be like the real Spit. The engine they are using develops a fairly respectable 266HP, whereas the Merlin started off at 1100HP and was developed up to 2070HP. That would be fun in a miggie !
« Reply #8 on: 25 October 2007, 19:25:21 »
There's nothing on this earth that sounds as good as a Merlin as well :y
Ken T
  • Stockport
« Reply #9 on: 25 October 2007, 19:26:15 »
Oh I nearly forgot, one idea definately worth "borrowing" is that it has a dual set of sensors, and can switch over between sets while running. Just think if the crank sensor fails, you can switch over to the alternative set. In fact they recon it will run on only 4 pots !. Wonder what mileage they have between  cambelt changes ?  ;D
Ken
