Author Topic: Whats Killing the Battery??  (Read 5641 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 10 June 2008, 19:05:35 »
Some thing is killing my Battery (Omi 2.5 TD CDX Estate) and I’ve now run out of ideas, any help?
It started a few weeks ago, is intermittent and has done it 4 times now, always when you least prepared for it, If you park up and come back after a couple of hours the Battery would be totally dead (having got round the dead locking and opening the bonnet), the battery is down to 2 Volts!,  jump start perfect, charge Battery still perfect until the next time.
This is what I’ve checked so far:
Checked Battery fully charged, fine 12.6 Volts off 13.9 Volts on. Changed Battery anyway.
Checked Alternator, fine, will fully charge a dead Battery in about ½ an hour.
Checked both cooling Fans, fine, both run ok and switch off as they should.
Checked alarm, not going off.
Checked and disconnected both interior lights.
Checked Radio not on.
Checked lights are not left on.
Left the Car alone for the last few days, and periodically checked, all ok, started late last night, on the button, this morning dead, cant even get in.
Obviously some thing is draining the when switched off?, but as I said I’ve run out of ideas!
Chris.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Whats Killing the Battery??
« Reply #1 on: 10 June 2008, 19:22:22 »
I know the feeling :(
I like red cars
zirk
  • Epping Forest
« Reply #2 on: 10 June 2008, 19:32:24 »
Yea, I did read your bit, but my TD not a FaceLift, in any case I cant see 700ma killing a fully charged Battery in a couple of hours.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #3 on: 10 June 2008, 19:33:53 »
I agree, sorry I can't help :(
I like red cars
Bandit127
« Reply #4 on: 10 June 2008, 19:38:59 »
A lead acid battery is dead at 10V... The chemistry is kaput and it wont charge back from there.
I suspect a poor ground connection is more likely. Where are you measuring the 2V?
« Reply #5 on: 10 June 2008, 19:39:37 »
Pull the HRW relay, just in case. Seen a CDL motor do same thing as well.
zirk
  • Epping Forest
« Reply #6 on: 10 June 2008, 19:44:20 »
Ive replaced the Battery (thinking it might even be intermitant).
Im  measuring the 2V (after the incident) across the Battery Lugs only and the Leads.
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #7 on: 10 June 2008, 19:44:25 »
your not parked near an airport?
I know that some radio key fob systems are on a similar frequency to the ATC at airports so when they transmit the car starts looking for the information.
zirk
  • Epping Forest
« Reply #8 on: 10 June 2008, 19:46:46 »
No, no Airport, dont have a Fob for the Car, Key only.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #9 on: 10 June 2008, 19:47:40 »
Sounds like a sticking relay.
I like red cars
zirk
  • Epping Forest
« Reply #10 on: 10 June 2008, 19:53:49 »
TB, I take it your refering to Heated Rear Window relay?
« Reply #11 on: 10 June 2008, 19:56:47 »
yes
zirk
  • Epping Forest
« Reply #12 on: 10 June 2008, 19:59:36 »
Doing it now, any more?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #13 on: 10 June 2008, 21:25:14 »
Feel all the relays, are any of them warm?
I like red cars
Omegatoy
  • UK
« Reply #14 on: 10 June 2008, 21:29:41 »
Hmm try this, look down the side of the battery and you will see 2 wiring connectors clipped to a bracket, lift them out of the way and you will see the brake pipes from the abs unit ,study this very carefully where the wires rest on it and check the wires for chaffing
found a few with this fault which eventually burns out the loom!!!
not saying it is the faut you ave but it maybe!!
