Author Topic: A/C water drain hose  (Read 1714 times)
MV6Man
  • Finland
« on: 24 June 2008, 18:57:09 »
Where is it, i donīt find it.
Even if i use A/C for 15 minutes on my garage, i donīt see any water anywhere under my car.
Is it common on these to be blocked or does it drop itīs water over exhaust or something?
hotel21
  • The Kingdom of Fife
Re: A/C water drain hose
« Reply #1 on: 24 June 2008, 18:59:39 »
It can drop onto the floor, as far as I recall....  Could simply be onto the engine/gearbox block and evaporating - or your weather is particularly dry at the moment!
MV6Man
  • Finland
« Reply #2 on: 24 June 2008, 19:07:00 »
Where is that pipe located under the car.?
Could it be tested if i connect a hose to it and blow hard, i suppose that it should go straight to aircon unit?
And no to dry , weather is pretty moist now...
MV6Man
  • Finland
« Reply #3 on: 02 July 2008, 13:56:34 »
I found two hoses under the car, left one is longer, and right one is just 2 or 3 cm long.
When engine is running and AC on it blows cold air through these so i presume that these aint blocked? Is it working correctly?
Iīm thinking that i may have an faulty hbv because my heater matrix gets pretty hot even when ac is set to low.
My car has extra pump in heater pipe, i thought that i could unplug it in summer so that it doesnt heat up so much, has anybody ever tested it unplugged?
And one question more. Where is that mixer flap located so i could make sure that it operates correctly?
« Last Edit: 02 July 2008, 13:58:03 by MV6Man »
MV6Man
  • Finland
« Reply #4 on: 04 July 2008, 07:23:51 »
Okay, changed that HBV yesterday, Now those matrix pipes wonīt get so hot anymore.
Old oneīs part number is 90 566 947 and new one 90 457 649.
I noticed that when i had those both in my hands. Only difference i found was in that valve what moves up and down.
My epc tells that 649 one is for finland,norway and sweden.
« Reply #5 on: 04 July 2008, 09:36:45 »
Thats weird, cant think why they would have a different HBV code for colder climbs.
