Author Topic: 2.2 Facelift Spark Plug Gap  (Read 3871 times)
Re: 2.2 Facelift Spark Plug Gap
« Reply #15 on: 12 July 2008, 13:05:48 »
4 pot cam cover gaskets easy.  Ensure the breathers and throttle body are cleaned as per Audo Addicts guide in Maintenence Guides section, else you'll blow the new ones as well.
Brian T
  • Addiscombe, Surrey
« Reply #16 on: 12 July 2008, 18:12:08 »
Well I've stopped sulking now and weather permitting will attempt the gasket change and probably the breather clear out next weekend.
The timing belt also needs doing but that may be just a bit too far for my brown trousers I might need bycicle clips as well!!
Thanks for all the advice today guy's  [smiley=dankk2.gif]
Illegitimis nil carborundum
davlad22
  • Sunny Yorkshire
« Reply #17 on: 12 July 2008, 19:28:47 »
The car rarely does in excess of 2k miles per year
Blimey! What mileage is on it now then??? Good luck with the work  :y
Brian T
« Reply #18 on: 13 July 2008, 10:13:50 »
I've just passed 80k it had 68k on it when I bought it in 2004.
Since I started work in the City I have to get the train so the missus uses the car more than I do.
Once I've done the work I think regular length trips might be in order to help blow the cobweb's out of the pipes.......It might help the car as well :)
« Reply #19 on: 13 July 2008, 11:01:19 »
see how you feel after the cam covers, belt not to bad on 4 pot. more regular oil changes will help keep breathers clear,as will longer journeys. :y
