Author Topic: MV6 door check strap  (Read 1658 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
« on: 17 July 2008, 19:17:38 »
door strap the bit that goes in the door has fell off i think!
door closes and wont hold open! very heavy doors!!!
Re: MV6 door check strap
« Reply #1 on: 17 July 2008, 19:21:24 »
This might help...
http://www.omegaowners.com/forum/YaBB.pl?num=1152902108
but yours might have gone too far already :(
Should have replaced the bush once it started making a noise .. :(
omegaaaa
« Reply #2 on: 17 July 2008, 19:23:32 »
Must be something in the wind because mine has just packed up as well
For the last few weeks it was creaking and sticking and making a horrible noise when I opened the door
Then it jammed...with my door half shut .... at the motorway services!
I gave the door a hefty shake backwards and forwards and the plastic bit inside the door where the metal bit goes into (technical term) must have broken because now the door shuts silently and smoothly!
I have the same problem as you now, the door wont stay open....but its ok...I just park on the flat!
« Reply #3 on: 17 July 2008, 19:36:08 »
At that stage 30 minutes and 50 p would have fixed it properly  :(
(not that you wish to know that now .. but any one else reading this with a creaking door .. MEND IT...  NOW ... it really is one bolt and one small piece of plastic .. :( )
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #4 on: 17 July 2008, 19:44:08 »
funny thing was i read that guide yesterday and put an order in for the bush at vx but its on order :(
its broken big time then? how do i fix it properly? i am getting new f/l doors soon so ill live with it if it costs alot to fix
« Last Edit: 17 July 2008, 19:45:24 by tmx »
« Reply #5 on: 17 July 2008, 19:47:09 »
If you look at the front edge of the door you'll probably see two holes torn out of the metal where the two securing bolts should be. :(
Repair would be to retrieve the broken bits from inside the door, then weld or bolt reinforcing plates to replace the torn metal, refit the dropped bits ... REPLACE THE NYLON BUSH .. and hope .. :(
