Author Topic: bad cold starting  (Read 3791 times)
colin
  • wigan lancs
bad cold starting
« on: 01 July 2008, 11:52:58 »
Please help my dad has bought a 2001 omega 2.2cdx auto he decided he wanted one after driving mine but he has a problem, it takes 3 or 4 attemps to start from cold then splutters for 20 seconds then runs fine all day, just changed oil,filter, air filter and plugs but it was still the same this morning please help any ideas would be greatly appreicated
ians
  • Reading
Re: bad cold starting
« Reply #1 on: 01 July 2008, 12:59:37 »
Worth changing the fuel filter for starters - its often neglected.
I would also recommend cleaning out the breather pipes/throttle body/idle control valve etc.  There is an excellent guide in the maintenance section on here.  Its an easy job and makes a world of a difference.
Give these a go - won't do any harm - and see how it goes then.
colin
  • wigan lancs
« Reply #2 on: 01 July 2008, 13:24:10 »
checked all breathers and throttle body all clear its wierd because once started, it starts all day after no problem and it runs excellent no misfires or splutters its just that stone cold starting issue.
rickyboy
  • Glasgow
« Reply #3 on: 01 July 2008, 13:41:45 »
What rpm does it idle at?  I had problems starting due to mechanical idle being mucked about with (by me - no-one else to blame I'm afraid)?
jimmas
  • stevenage, herts
« Reply #4 on: 01 July 2008, 13:47:36 »
Dis pack maybe, camcover leak causing oil to leak into plug holes and cover plugsl.
« Reply #5 on: 01 July 2008, 13:54:21 »
Although I'm not a mechanic
checking order should be
fuel delivery ,
ignition components  (sparks , cabling and other)
compression testing..
also solution could be as simple as air leak from gaskets..
« Last Edit: 01 July 2008, 13:55:57 by cem_devecioglu »
colin
  • wigan lancs
« Reply #6 on: 01 July 2008, 13:54:49 »
idle is about 800rpm and smooth, once started from cold after at least three attemps it wont seem to rev just spits and pops after 20 secs it runs perfect :(
rickyboy
  • Glasgow
« Reply #7 on: 01 July 2008, 14:58:48 »
Not idle problem then.  Either too much fuel or too much air.  Check for air leaks first.
colin
  • wigan lancs
« Reply #8 on: 02 July 2008, 12:20:20 »
Just found small breather hose blocked up with a hole in it, it had also gone almost chewy like, done a strip down all hoses and throttle body cleaned with carb cleaner offending hose replaced all blown through and dried with compressed air,hope its done the trick ;) we will see tonight. Thanks for all your help and sugestions ;D
colin
  • wigan lancs
« Reply #9 on: 02 July 2008, 19:38:13 »
Not made slightest difference exactly the same. :(
rickyboy
  • Glasgow
« Reply #10 on: 02 July 2008, 19:57:44 »
Check the plugwells for oil as jimmas says and another favourite is to take the plug cover off in the dark and see if you have a firework display.
« Reply #11 on: 02 July 2008, 20:16:33 »
Worth checking for fault codes, esp as 2.2 eats up cam sesnors, which make them a bugger to start
colin
  • wigan lancs
« Reply #12 on: 02 July 2008, 22:33:17 »
cheers for that,booked in saturday morning for diagnostic as eml came on today but gone off again.
colin
  • wigan lancs
« Reply #13 on: 13 July 2008, 10:09:07 »
diagnostic showed crank sensor open circuit, new one fitted yesterday but still a pig to start this morning. so this cured eml but not the original cold start fault aghhh.
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #14 on: 13 July 2008, 10:25:28 »
Hi
Had the same prob with my car a few months or so ago with mine it was a very small hole in one of the rubber fuel pipe in the fuel pump unit in the boot of the car.
I just removed carpet and removed the    4 srews on the plate removed the twist off top of the pump and checked the rubber line.
Cut the pipe back reconected and all has been fine since.
hope this is of help :y
I will PM you my details if it will help
Page created in 0.031 seconds with 20 queries.
