Pages: 1 2 [3]  All   Go Down
Author Topic: engine management light on  (Read 5921 times)
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
Re: engine management light on
« Reply #30 on: 28 July 2008, 13:07:02 »
Help required here too on this subject although mine is a v6. Light has just come on but have no aparrent mis-firing or juddering. never done this before in 18 months of ownership. Anyone in my area with a fault code reader i could use would be brill ( by pure bad luck the wife's Corsa has the same light on)
Cheers......
               Keith......
What year is yours? Can you paperclip it?
rickyboy
  • Glasgow
« Reply #31 on: 28 July 2008, 13:42:50 »
I have the same problem on my 2.2 lit petrol, although it doesn't occur very frequently (yet) and only for a short period of time. This mostly happpens in hot weather.
Cam sensor the best guess here? Is it placed the same as on 2.0 lit?
Thanks!
Could be anything bringing up the code tbh.  You would be better getting the codes read by a garage or buy yourself a cheap tech 2 code reader to get the codes yourself.
You may be able to do the pedal trick although I've not yet seen it work on a 2.2.  Press the accelerator and the brake pedal to the floor with the ignition off.  Keep the pedals pressed down then turn the ignition onto position 2.  If the engine management light starts to flash write down the sequence.
There is absolutely no guarantee your camsensor is at fault without the relevant code to confirm it.  You may end up throwing your money in the fire.
Canon Cam
  • Ferdown/bournemouth
« Reply #32 on: 02 August 2008, 13:26:18 »
hi again guys,
Silly question...but I would just like quick confirmation on my engine type so I can order a new cam sensor.
Car is as on left.........2000 (W plate) 2.0L GLS Auto.   Am I correct in saying the engine is X20XEV ????
Thanks
Canon Cam
« Reply #33 on: 02 August 2008, 15:50:01 »
Can anyone confirm the above...I am keen to order today so I can have the part on tuesday.
Thanks
Grumpy
  • Manchester
« Reply #34 on: 02 August 2008, 15:54:06 »
Thanks
Yes
« Reply #35 on: 02 August 2008, 18:21:26 »
Thanks!
asautocare in wigan(?) if i remember correctly. The 2.2 has no
Way of flashing codes as far as we know. So you need a
tech 2 diagnostic. Dont quote me on the name but i saw it
On here somewhere tech 2 diagnostic for 30 quid. Worth a
search. Hope helps.
« Reply #36 on: 02 August 2008, 18:34:48 »
bloody hell. Have we gone mad with error codes recently or
what? Rickyboy been busy with the 4 pots. Given up counting
On quoting the pedal trick! Anybody fancy doing a guide?
rickyboy
  • Glasgow
« Reply #37 on: 02 August 2008, 18:41:05 »
Tell me about it, engine lights and omegas seem to have a real love for each other, never apart for too long!  I think you may have just nominated yourself to do the pedal trick guide!  ;D :y
« Reply #38 on: 02 August 2008, 22:38:02 »
      Sh!t
Pages: 1 2 [3]  All   Go Up
