Author Topic: Rebuilding a manual gearbox  (Read 3571 times)
« on: 28 October 2007, 01:24:15 »
Hi Guys,
I am considering the possibility of obtaining a second hand manual gearbox, and totally overhauling / reconditioning it, to the extent that it's as good as new.
This is not something I've ever done before, so I'm not sure what tools would be required, what parts I would need, or what the availability and cost of them would be, or if it would be within my capabilities.
Expert advice please :y
miggy
Re: Rebuilding a manual gearbox
« Reply #1 on: 28 October 2007, 03:05:46 »
Hi Guys,
Hats off for trying
 :y :y :y
« Reply #2 on: 28 October 2007, 03:08:07 »
Boxes are common enough, there's not much to lose!
miggy
« Reply #3 on: 28 October 2007, 03:10:05 »
Only your sanity
 ;D ;D ;D
« Reply #4 on: 28 October 2007, 09:44:01 »
And this replacement gearbox? You are planning on fitting on my tractor?
Taxi_Driver
« Reply #5 on: 28 October 2007, 09:50:42 »
You want a manual tractor  :o :o
« Reply #6 on: 28 October 2007, 10:36:57 »
The auto simply doesn't suit it. I am constantly shouting at the bloody box for being so stupid...
« Reply #7 on: 28 October 2007, 10:44:36 »
Would you also need to change the prop shaft if converting to a manual?
« Reply #8 on: 28 October 2007, 14:27:41 »
Not checked, but would imagine they are the same...
Taxi_Driver
« Reply #9 on: 28 October 2007, 16:38:10 »
Ohhh......I dont like to ask if its got the latest version on the g/b ecu  ;) :P
    • 530D M Sport, 330i Coupe
« Reply #10 on: 28 October 2007, 16:47:30 »
Is it the four speed (4L30E)? Wonder what the five speed (5l40E) would be like in it?
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #11 on: 28 October 2007, 17:05:16 »
I have rebuilt several boxes over the years and although it can be done if you have common sense and a decent set of tools, and i know you have both James, it does depend on what you want at the end of the day. To buy all the bits, new bearings, washers, thrust rings etc etc it will cost you nearly as much as an exchange recon box with some guarantee, but, and here is the but they tend to only replace what needs replacing, if however you do the job yourself you will replace everything and know what is in the box, if this makes sense.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #12 on: 28 October 2007, 17:09:44 »
 I'm not up on my gearboxes... especially autos... which (if any) Omegas came with a five-speed auto?
« Reply #13 on: 28 October 2007, 17:18:45 »
Hardly any! apparently the very end of line Diesels did (It's listed in the manual with my car).
As the TD is really at it's best when 'on turbo' I wondered if the five speeder would suit the characteristics of the 2.5TD better? I believe that's the reason why VX fitted it to the 4 pot TD's at the end.
Paul M
  • Edinburgh
« Reply #14 on: 28 October 2007, 18:01:08 »
Hi Guys,
The question is, why do you want to? If it's for the engineering learning experience then fair enough, but otherwise I don't see the point. They rarely fail, and in the off chance that you're unlucky and it does fail then pick up a used one for peanuts -- due to lack of failures there's no demand for them on the used market meaning they're super cheap, and you'd be unlikely to have two fail unless you're running big power.
The only real failure point (wear and tear actually) is the clutch, and as you've replaced that you should be good for at least another 100K.
