Author Topic: Im new so be gentle with me.... Faults  (Read 1731 times)
eastwood
  • North East
« on: 04 August 2008, 21:15:35 »
HI all
Im new... but dont let that put you off
When I turn her on i get the following appear on the digital display
low beam
fld vision
should i be worried???
also get
F   C
on the temperature pane
uh and I know its hard to describe noises on here but there is a distinct knocking from the oggside front over rough ground
It does it when in neutral and witht he engine off.
Any ideas......any common faults???
any way im sure ill be here lots!!!
take care all
Stu
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Im new so be gentle with me.... Faults
« Reply #1 on: 04 August 2008, 21:19:53 »
Low Field is a faulty Xenon sensor front or rear wishbone cant remeber which side sensors are on but i thbink the rear is passangers side
or could be faulty lifter motors if you search the forum for the error message it should bring up a fair few topics about it
F on theremo is a faulty thermo sensor i think they sometimes pack up dont know how to replace it but on the vectras it lives in the front grill so i assume its the same on omega
knocking sounds like a bushing or track rod bushing any competent mechanic can diagnose which one it is!
dont worry too much though they are all relatively simple and cheapish problems to fix! common omega problems!
« Last Edit: 04 August 2008, 21:20:38 by tmx »
« Reply #2 on: 04 August 2008, 21:25:21 »
Headlight fault will be popped off sensor, or failed servo.
F C means the outside temp sensor has failed - lives behind bumper (near middle on facelift, passenger side on prefacelift)
RolandL
  • Doncaster
    • M/facelift 2.5 V6 Elite
« Reply #3 on: 04 August 2008, 21:26:13 »
Hi, had the same message on my car a while back.......Have a look where the front wishbone is hinged against the chassis leg, about midway front to rear, under where the electrical wires are.  You should see a rod about 2 inches or so long which connects a plastic gubbins about the size of a matchbox to the chassis leg.  If you imagine the suspension moving when you are driving, it reads the relative movement of the parts and adjusts the headlamp aim accordingly to avoid dazzle.
The rod should be ok, the culprit on mine was the black plastic bit (kept popping out) held it in place with 'lastic band till i could scource a replacement from the scrappers.
hth
Regards
Roland
ps if you have a pre 2000 car you will have one mechanism o/s and another on the n/s later cars only had one I believe
The faster you go the bigger the grin.  Trade card user.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #4 on: 04 August 2008, 21:36:38 »
Item 13 has a habit of popping off  :y
Trade club card holder
Code scanner available
Bandit127
« Reply #5 on: 04 August 2008, 21:40:42 »
Hi Eastwood.
On an old Corsa, FC meant the ECU didn't know what the outside temperature was. So heavy consumption and poor starting was caused by the ECU using the choke too much.
Omega is multi-point injection so probably less sensitive. But the bit for the Corsa (back then) was about £7 and a piece of cake to change.
Unplug old one. Plug in new one...  :)
« Reply #6 on: 04 August 2008, 22:08:12 »
Stu
Drop links - Ebay around £7 each.  Easy to swap - around 20 mins per side.
Try http://cgi.ebay.co.uk/VAUXHALL-OMEGA-FRONT-ANTI-ROLL-BAR-DROP-LINKS-X2_W0QQitemZ230263750281QQcmdZViewItem?hash=item230263750281
Fit both "oggside" and "negside" ones  :-? :-?
« Last Edit: 04 August 2008, 22:10:04 by dbug »
eastwood
  • North East
« Reply #7 on: 04 August 2008, 22:26:34 »
what a fantastic place this is!!!
thanks guys....
just to show how new I am...er whats t he difference between facelift annd preface lift!!!
Stu
« Reply #8 on: 04 August 2008, 22:43:06 »
Wot model do u drive - update your profile - makes help that much easier.
Look at http://www.omegaowners.com/forum/YaBB.pl?num=1162323406
Roughly pre facelift - pre 1999 - facelift 1999 or 2000 on - depends when registered.  No doubt i will be corrected if i got it wrong :-/
Bandit127
« Reply #9 on: 04 August 2008, 22:53:59 »
People will kill me for this...
But.., the facelift has the butt ugly 'corporate' Vx grill. And butt ugly double row lights at the back.
Among other things. Like bigger engines, more sophisticated suspension, better interiors....
The MV6 lost the lowered suspension.
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #10 on: 04 August 2008, 23:08:54 »
..and then there's the "mini-facelift" to throw into the mix, but the changes were minor (from what i read!).
I'm happy with my "original" old boat...
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #11 on: 04 August 2008, 23:10:15 »
Prefacelift Recaro sports leather is far superior to any mainstream cars leather in my opinion!
Page created in 0.032 seconds with 20 queries.
