Author Topic: Where's the HEGO sensor on a 2.0l ?  (Read 1315 times)
the_bed_wrecker
  • SUNNY HARTLEPOOL
  • Where's that stormtrooper gone ?
« on: 08 August 2008, 12:40:28 »
Where's the HEGO sensor on a 2.0l ? and can it be cleaned ?
Thanks
TBW
PS How can you get to mechanical stuff like this with a TIS manual ?
Must be getting old to have one of these !!
Re: Where's the HEGO sensor on a 2.0l ?
« Reply #1 on: 08 August 2008, 12:42:41 »
Thanks
TBW
On the exhaust, just before cat
TIS - under Service Information
« Reply #2 on: 08 August 2008, 15:17:03 »
Heated Exhaust Gas Oxygen sensor. Is that the same as a lamda sensor? Should be able to unbolt it. 2 wires on the end, carefull the wires can be
Damaged or break from the heat/oil/road crap.
« Reply #3 on: 08 August 2008, 15:57:31 »
yup. hego = lamda
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #4 on: 09 August 2008, 09:32:15 »
Would carb cleaner be OK to clean it ? Does the sensor work of a 12V supply so I can check the wires.
Thanks
TBW
« Reply #5 on: 09 August 2008, 09:40:38 »
no, ultrasonic bath to clean.
iirc, 2l ones are 5v - might be wrong though
the_bed_wrecker
  • SUNNY HARTLEPOOL
« Reply #6 on: 09 August 2008, 09:45:49 »
Hi, Ok I got a Ultrasonic cleaner (usually used for doing bike carbs), I usually use petrol first (a bit bad as it gets hot) then water/washing liquid to rinse it off. Have you any recomendations for doing this lamda sensor ?
Cheers
|TBW
Page created in 0.031 seconds with 20 queries.
