Author Topic: Petrol smell in Coolant  (Read 7342 times)
markey mark
  • SLady bitshorpe north lincs
Re: Petrol smell in Coolant
« Reply #15 on: 12 August 2008, 10:39:55 »
Can't find anything obvious, but with the bonnet up & the engine running I was very aware of the 'fan belt' tensioner bearing being as dry as a witches .... . With the belt removed to remove the roller (seal popped off & a little grease added) I can feel some play in the pump.
I eventually managed to order another pump from the dealers - had to go down there in the end  >:( - so I'll start stripping it down.  :(
be best to change it andy mate  :y
« Reply #16 on: 12 August 2008, 12:54:56 »
The new pump is in a box next to me, unfortunately I've run out of time before I go to work.
The old pump is definately beyond its best, play in the bearing, & there's some evidence of pink antifreeze underneath. Fingers crossed that this is the only place I'm losing water from. :-?
sassanach
  • trowbridge
« Reply #17 on: 12 August 2008, 13:23:04 »
if you can smell petrol in the coolant then sooner or later you are going to have to bite the bullet  and change those head gaskets.
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #18 on: 17 August 2008, 13:56:24 »
In between rain showers, I checked the compression on the engine. Here's what I got.
1. 185 PSI
2. 185 PSI
3. 185 PSI
4. 185 PSI
5. 165 PSI
6. 185 PSI
I repeated the test twice to confirm.
What's that sound like?
Growing old disgracefully...
Paulus
  • Wheaton Aston
« Reply #19 on: 18 August 2008, 09:02:25 »
1. 185 PSI
2. 185 PSI
3. 185 PSI
4. 185 PSI
5. 165 PSI
6. 185 PSI
Anybody?  :'(
« Reply #20 on: 18 August 2008, 09:04:44 »
Thats about 1.5bar down...  ....not massive, but I guess could be failing.  If you smell fumes in header tank though, thats fairly conclusive...
Paulus
  • Wheaton Aston
« Reply #21 on: 18 August 2008, 18:05:27 »
Well it'll have to wait a few weeks (hopefully). I'm off to Cornwall at the weekend.
