Author Topic: my wishbones  (Read 3559 times)
Re: my wishbones
« Reply #15 on: 18 August 2008, 21:32:17 »
cool ta.
would the old 'big washer little washer' trick do it? ie using a very long threaded bolt and a mahusive washer to squeeze the bushes in?
Is there any benefit at all in buying bushes from another company? ie performance ones?  do they really make any difference to handling over pattern poly ones?
Needs a 10 tonne press, and thats borderline...
I'll agree to that!!
Nah, a 6 ton one (bottle jack) on a home made frame pumped until the safety valve is popping (so about 8-9 ton) and then a light tap on the runner with a lump hammer works well.
The correct drifts are the hard thing to get, just like I have in the garage  :y
Re: my wishbones
« Reply #16 on: 18 August 2008, 21:41:27 »
cool ta.
That safety valve that popped, it wasn't the jack's, it was mine ;D
« Last Edit: 18 August 2008, 21:41:40 by TheBoy »
Re: my wishbones
« Reply #17 on: 19 August 2008, 00:46:07 »
yep, and me, will be along shortly, i am feeling guilty having left it so long since the knowledge day
But my arse will be in gear soon. Set up, will bring an idler just in case and 2 rear boots, falkens maybe?  :y
« Last Edit: 19 August 2008, 00:49:00 by chrisgixer »
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: my wishbones
« Reply #18 on: 19 August 2008, 12:41:38 »
cool ta.
what do the drifts look like,  any pictures ?
& sizes avilable, please.
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
platty
  • Cambridge
    • BMW 530d Sport
Re: my wishbones
« Reply #19 on: 19 August 2008, 13:16:37 »
I had some wishbones from Buypartsby.com a year or so ago - didn't follow the guide on here (what a d1ck) and ended up tightening the n/side up whilst the wheel was hanging low. So its dead 1 year later... and then I read the guide!!  :-[
Just bought some from vail68 on eBay (£45 for a pair delivered) - says they are FAI - either way they must be better than the previous ones I put on - they were a different brand left to right  >:(
Got a set of bolts off Andyc for £9.20+ so jobs' (should be) a goodun!
« Last Edit: 19 August 2008, 13:18:09 by platty »
sassanach
  • trowbridge
Re: my wishbones
« Reply #20 on: 19 August 2008, 18:33:57 »
i find that a 100 ton brake press works much better! :)
Page created in 0.238 seconds with 16 queries.
