Author Topic: aux belt tensioner ongoing problem  (Read 2110 times)
Re: aux belt tensioner ongoing problem
« Reply #15 on: 21 August 2008, 18:11:39 »
only had cambelt done 5k ago at dealers so it better not be that >:( >:(
will go pop belt off in a min and have a listen
is that 5k less than a year ago? if so, should still be under warranty
thankfully it's not the cambelt. unfortunately it's the soddin alternator.
anybody know where i can get 1 from urgently. going away for weekend tomoro afternoon so need it changing.
If your reasonably compitent then you can change the bearings, not hard and they are available form most bearing factors for under a tenner the pair.
